586,460 active members*
3,205 visitors online*
    Dec 2014
    187
    Why is my RDWorks image Backwards?
    Just started using RDWorks and going by a lot of Goggling I haven't found the solution to these two problems
    1) I found that the Axis X Mirror shouldn't be checked but when I send the job to the Laser its Flipped on the X ( Backwards ) ( See Attached )
    2) Laser Head Position I have as Top Left but its hanging around the Top Right? ( See Attached )
    Apr 2006
    108
    Re: Why is my RDWorks image Backwards?
    The problem is with the ”Screen Origin”
    Press theZ/U button to go to the menu screen.
    Press the”Screen Origin” button to select that feature
    Press the Z/U button to change the screen view direction
    Press “enter” to keep the setting.
    Press “escape” to exit the menu.
    Ray Scott
    Rabbit Laser USA
  1. RDWORKS NEED HELP PLS....
    By bossing in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-17-2017, 05:13 PM
  2. RDworks Questions
    By Dtcrafts in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-09-2017, 09:50 AM
  3. Am I doing this backwards?
    By Philosofy in forum Uncategorised CAD Discussion
    Last Post: 02-14-2017, 03:05 AM
  4. RDWORKS V8 Question
    By trrubicon06 in forum Laser Control Software
    Last Post: 12-25-2016, 06:35 AM
  5. BobArt - No Image after "Load Image"
    By TAProwler in forum BobCad-Cam
    Last Post: 12-24-2010, 06:05 PM
