586,070 active members*
3,607 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > dooan 7500 mill 2161 lub pressure down alarm
Results 1 to 3 of 3
    Mar 2018
    I am getting this alarm quite often. the gauge action if fine. I am getting it when the pressure is in the green. sometimes the pump cycles right but sometimes it will cut on as soon as you move an axis and wont cut off until it alarms out. can anyone help?
    Feb 2013
    788
    Re: dooan 7500 mill 2161 lub pressure down alarm
    If the gauge is truly displaying correctly, and you are understanding it correctly, then the likelihood is that the pressure switch is failing. This can be verified by checking the actions of the I/O signal of the switch.
    Doosan Service Technician
    [email protected] O:973-618-2461 M:973-803-9479
    Mar 2018
    I verified the switch was not working by the action of the I/O. I changed the switch and it fixed the problem thanks.
  1. ALARM 2161 LUBRICATION OIL PRESSURE DOWN
    By Michael82 in forum Daewoo/Doosan
    Last Post: 02-21-2018, 01:47 AM
  2. Puma 400 lube pressure down alarm 2161
    Last Post: 07-15-2015, 09:04 PM
  3. Leblond / Fanuc OM Lube Pressure No 2050 Oil Pressure Alarm
    By alcarinc in forum Uncategorised MetalWorking Machines
    Last Post: 01-13-2015, 03:02 AM
  4. Mini Mill Low Pressure Alarm
    By Mike T. in forum Haas Mills
    Last Post: 06-26-2014, 05:48 PM
  5. Replies: 4
    Last Post: 06-12-2009, 09:15 PM
