The thread mills that Tormach sells are all four-flute single-form so they can cut any pitch threads. Assuming that I purchase the right pitch is there any reason that I cannot use a multi-tooth cutter (https://www.maritool.com/p846/Thread...duct_info.html) in a Tormach? I assume that I should start at the bottom of the hole to make best use of the multiple teeth. Any special precautions?
