Just wanting to know if it's possible to adjust the minimum rpm you can rigid tap on as someone at work managed to mess on with the parameters and get the machine to run all the way down to 2 rpm.
However you can't run less than 110rpm when rigid tapping, what would be nice, if I could get it as low as 100 just for ease of programming feeds so not having to calculate it out every time or use g95/g94 to turn on the feed per rev, then turn it off again, as all programs are hand typed at the minute so its just more remember or write down in books as a reference.
