586,058 active members*
4,658 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > is this problem due to heat treatment
    Aug 2007
    224
    Hello everyone.. please check jpeg for complete details...I am facing issue regarding stability of geometry and sizes of that part...
    Fsa
    15362
    Re: is this problem due to heat treatment
    Quote Originally Posted by fsa View Post
    Fsa
    With case Hardening you will get a lot of material movement, normally when you need to keep a tolerance on a heat-treated part, like this, it is Ground lapped after heat-treatment
    Mactec54
    Aug 2007
    224
    OK your suggestion is laping...but do you think that laping can solve bord geometry issues..... right now my focus on hardening process ..I don't want to do any other operations after hardening...??? looking advice about hardening process...
    Asif
    Aug 2007
    224
    Asif
    Jun 2010
    4256
    Tough.
    You will have to.
    Cheers
    Roger
  1. Gummy 6061 Aluminum Rod - Heat Treatment Options?
    By cjjonesarmory in forum MetalWork Discussion
    Last Post: 08-09-2010, 01:49 AM
  2. heat treatment issue plz help
    By fsa in forum Mechanical Calculations/Engineering Design
    Last Post: 08-15-2009, 04:55 PM
  3. Heat treatment of stainless steel.
    By zoeper in forum MetalWork Discussion
    Last Post: 12-18-2008, 03:19 PM
  4. Heat treatment for lathe spindle shaft
    By mackeym in forum Uncategorised MetalWorking Machines
    Last Post: 10-15-2007, 10:05 PM
  5. Heat Treatment
    By georgebarr in forum MetalWork Discussion
    Last Post: 04-18-2004, 07:08 PM
