586,103 active members*
2,751 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Encoders for Nema 23 Stepper motors
Results 1 to 6 of 6
    Apr 2006
    113
    I am thinking of adding encoders to my xylotex set up using rogers interface board....what encoder do I need and were to get it...and has anyone done this yet?
    Jim
    May 2005
    2502
    US Digital has inexpensive encoders that will likely fit your motors. Take a look through their web site.
    Best,
    BW
    Jul 2005
    2415
    Are you losing steps now?
    Are you afraid of losing steps?
    Are you scraping work because of lost steps?
    If you are losing steps it's better to address the cause even if you do decide to go with the position "monitor" system you listed.
    All the encoders will do is shut the machine down if the position error is greater than a preset value.
    With steppers they lose postion because they have been asked to do something they can't (outside the torque envelope of the motor) so there is nothing you can go in a closed loop system but slow the motor down to bring it back inside it's torque curve. Simply adding in more steps (which is not what the Rogers Board does) just results in adding insult to injury.
    USDIgital E4 series with sticky adhesive works on most motors that have a rear shaft. You will need to get the centering tool they sell to install them and
    make sure you get the tiny connector with the wires attached for the encoder or you will find it impossible to hook them up (:-(
    Tom Caudle
    www.CandCNC.com
    May 2003
    323
    Encoders
    See my post and pix in "Encoders with steppers" below.
    Jack C.
    Jun 2007
    44
    Quote Originally Posted by jcc3inc View Post
    Jack C.
    what post and pics?? i don see it! know where i can read up on these encoders?
    i dont know sqat!!! will be asking dumb questions
    Dec 2006
    775
  1. Anyone using closed loops (encoders) on their stepper motors?
    By RMS in forum Stepper Motors / Drives
    Last Post: 08-04-2006, 10:23 PM
  2. Stepper motors and encoders
    By homebrewCNC in forum Stepper Motors / Drives
    Last Post: 03-30-2006, 05:57 PM
  3. Nema 34 Motors 434oz/in / which gecko
    By ckrantz in forum Gecko Drives
    Last Post: 10-01-2005, 09:21 PM
  4. What encoders to use for these motors?
    By Cold Fusion in forum Servo Motors / Drives
    Last Post: 06-03-2005, 05:14 AM
  5. Stepper motors, encoders...
    By runnoahrun in forum CNC Machine Related Electronics
    Last Post: 02-29-2004, 04:59 AM
