586,655 active members*
4,085 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Dual and single shaft stepper motor differences?
Results 1 to 6 of 6
    Jan 2007
    37
    What is the difference between dual and single shaft stepper motors? Searched the forums, but can't seem to find the answer....
    Aug 2006
    2758
    Quote Originally Posted by Menatep View Post
    The only real difference is that one has only a front shaft and the other one a front and rear shaft. Generally, electrical specs are the same. Different mechanical drawings.
    Jan 2007
    37
    So there's practically no advantage that one has over the other?
    Apr 2007
    36
    If you might want to add an encoder later, or perhaps need to run something from the back side yes. Otherwise, I can't think of any reason.
    Jan 2007
    37
    Excellent. Thank you for answering the question! You opened up my eyes
    Jan 2006
    245
    double shafted motors are also usefull if you want to manually move the motor.
    Fit a knob on the back and turn it manually.
    Motion Control Products Ltd
    www.motioncontrolproducts.co.uk
  1. Single vs Dual Lead Screws
    By Cold Fusion in forum DIY CNC Router Table Machines
    Last Post: 03-08-2009, 10:26 PM
  2. Dual stepper motor setup
    By Goose80 in forum Stepper Motors / Drives
    Last Post: 12-20-2006, 06:46 AM
  3. linear slides X-axis single side or dual?
    By PlasmaGuy in forum Linear and Rotary Motion
    Last Post: 02-16-2006, 06:44 AM
