586,043 active members*
3,762 visitors online*
Results 1 to 8 of 8
    Jun 2016
    48
    Circle problems
    Hello,
    I have build CNC, when I calibrate it with gauge indicator (10mm lenght, 0.01mm resolution) for example: go 3mm Y or X axis, gauge indicator shows 3.01-3.02mm. then go -3mm, indicator shows 0.01 or 0.02mm. Z axis is more accurate, resolution and repeatability is less than 0.01mm. For X axis I use 2 motors and two SFU 2005, Y axis same SFU 2005 ballscrew, for rails I use linear block rails. When I mill squares or corners, everything looks good, but when I mill circle - It looks awfully. there is pic of circles: https://imgur.com/a/lJfTn circles diameter 5 and 7 mm
    While CNC is milling circle, X and Y axis half of circle start moving with velocity and almost stops, then again start with velocity and stops. So as you can see in the picture, circle consists of two parts. I use mach 3, I try a lot of different cad's and cam's, but I have same problem. Any thoughts?
    Re: Circle problems
    You have a lot of backlash, or your screw or nut is loose.
    Jun 2016
    48
    Re: Circle problems
    when measuring with gauge indicator backlash is 0.02mm, so 20um. I bought new ballscrews. Sad, I will need to buy new ones. But that circle milling per two half's, how I can make that circle mills without any stops at half way?
    Re: Circle problems
    from the look of the cuts, I'd say you measured wrong, or something came loose.
    Can you post the g-code you used?
    Apr 2005
    253
    Re: Circle problems
    backlash or losing steps on the Y, but with the flattened section and the ends not meeting most likely as Gerry has said backlash
    I'll get it finished sometime after I start it.....
    Jun 2016
    48
    Re: Circle problems
    hello,
    I think I found problem, today I will try to fix it and then I will post results.
    Jun 2016
    48
    Re: Circle problems
    Thanks for help, after ger21 say about backlash I started to search where can it be. And I found it, ball screws support bearings were not fixed correctly , so I fix it and results: https://imgur.com/a/EElbO
    Apr 2005
    253
    Re: Circle problems
    Quote Originally Posted by Patuc View Post
    excellent, well done
  1. A circle, a simple circle. How hard can it be?
    By camasaki in forum Hobby Discussion
    Last Post: 07-18-2019, 09:21 AM
  2. Circle and arc problems
    By antoinedrouin in forum G-Code Programing
    Last Post: 07-07-2017, 10:05 PM
  3. Draw line tangent from small circle to large circle
    By WEDDLETON in forum ViaCad / Shark
    Last Post: 07-30-2014, 05:53 AM
  4. Replies: 16
    Last Post: 02-05-2014, 08:21 PM
  5. write gcode for circle with 4 small circle inside it
    By Farzaneh_2010 in forum G-Code Programing
    Last Post: 12-13-2010, 05:24 PM
