586,094 active members*
4,072 visitors online*
    Dec 2010
    18
    Amada NC9-F Control Parameter help needed
    Hi all,
    Been trying to get into the Parameter portion of a NC9-F Control on my FBD1030. When I press the "Internal System" button and press Parameters, nothing happens. It is not asking for a password which I believe it should be doing. Does anyone know how to do it.
    Thanks.
    Mar 2009
    101
    Re: Amada NC9-F Control Parameter help needed
    Quote Originally Posted by orbets View Post
    Hi all,
    Thanks.
    You may need to turn on switch 5 on MC111( do this with pwr off)
    Dec 2010
    18
    Thanks amadajoe. I'll give that a try. Next will be the 5lb sledge hammer.
  1. Parameter needed for Bridgeport Int. 412X. TNC 2500 control
    By Eric Tay in forum Bridgeport / Hardinge Mills
    Last Post: 08-22-2018, 06:46 PM
  2. AMADA LATHE CNC J5 parameter
    By hvsinh03 in forum Uncategorised MetalWorking Machines
    Last Post: 04-25-2017, 11:07 AM
  3. Amada NC9-F parameter need help
    By tu_2007 in forum Bending, Forging, Extrusion...
    Last Post: 06-29-2011, 09:18 AM
  4. Amada vela 2 parameter list for 20h motor
    By snow282 in forum Fanuc
    Last Post: 09-21-2010, 05:03 PM
