I have a PRO4896 with older rail system and NEMA 34 plug and play CRP800. Machine has been working flawlessly for two years now but tonight the spindle won't start up when I press cycle start in Mach 3 to run a program. Usually the spindle will start right up and then the machine goes to home and then moves out to start cut. It's doing all the moving, just without the spindle. One thing I noticed, and this probably has something to do with it - when I start Mach 3 I get a message that says MACH3/MACROS/MACH3MILL/not found I click on OK and the message repeats and then click on ok again and Mach 3 screen comes up - it's got my name and the CRP identifier in the bottom right hand side still. I've tried restarting a few times - different g-code etc .. Nothing. Have a project to run (was for tomorrow mornings job) so hopefully it's not the spindle. HELP Thanks
Oh, the spindle is the CNCRP one and their electronics plug and play
