586,103 active members*
2,629 visitors online*
IndustryArena Forum > Community Club House > Machinist Hangout > Rigid shaft coupling - need advice from experienced professional machinist
    Mar 2007
    23
    Hi, see picture of NEMA 23 motor to worm spindle coupling. This would be the recommended way to do this I guess.
    But that flex coupling is 1" long and for this small rotary table that means a lot of extra bulk just for that coupling. The motor will be totally enclosed inside the casing.
    What I really want to do is to remove the spindle shaft (right of right bearing), drill & ream to 1/4" for the motor's D-shaft and move the motor right up to the shaft shoulder.
    I know this is essentially a NO-NO, especially between rigid shafts and preloaded bearings.
    Runout, and wobble will need to be extremely low for this to work reliable over time.
    The work of machining these parts will be set out to a shop/factory.
    Should I even try this? Will they be able to get the needed shaft bore accuracy?
    Nov 2011
    137
    Re: Rigid shaft coupling - need advice from experienced professional machinist
    This Is just a thought,but could you remake that spindle shaft but reduce the shaft that goes to the stepper the same size as the stepper shaftThen remove the shaft with the hub that is on the stepper motor and put the hub on the shaft you had remade.that would do away with the coupling.
    Dec 2013
    5717
    A good shop can do the work for you and get it correct. But it might be expensive.
    Jim Dawson
    Sandy, Oregon, USA
  1. Looking for shaft coupling
    By lilimike in forum DIY CNC Router Table Machines
    Last Post: 08-29-2015, 08:02 AM
  2. Sale!!!Shaft coupling cnc router coupling coupler
    By zao in forum Want To Buy...Need help!
    Last Post: 08-29-2015, 07:59 AM
  3. Shaft coupling advice required
    By nick mulder in forum Mechanical Calculations/Engineering Design
    Last Post: 01-17-2011, 11:07 PM
  4. Rigid Coupling Vs. Flex Coupling
    By Johnsnd in forum DIY CNC Router Table Machines
    Last Post: 05-30-2009, 03:25 PM
  5. Looking for a Coupling for 1/2" motor shaft to KR33 6mm shaft
    By DonW in forum DIY CNC Router Table Machines
    Last Post: 03-17-2008, 09:58 PM
