586,082 active members*
3,716 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Oldham couplers for CNC - Nylon or Acetal disks?
    Sep 2011
    29
    Hello you extremely helpful bunch.
    I went to Ruland.com and ordered couplers, I got the 19.1mm OD version and I ordered 10 each of both the nylon and acetal disks:
    https://www.ruland.com/catalog/produ.../category/278/
    Anyone have any advice on whether to use the nylon or acetal disks?
    Steppers are NEMA 24 / 439oz.in / 3.5A driven at 48V
    Table is a 6040
    Thanks.
    Richard
    May 2005
    3920
    Re: Oldham couplers for CNC - Nylon or Acetal disks?
    I'd go with Acetal myself.
    Apr 2003
    540
    I believe the Acetel is firmer resulting in less backlash but it's going to be microscopic. The specs for each type/item should list how much. Acetel has low friction and is very machinable and is more common for CNC uses. Depending on the machine, you most likely won't see any real differences between the two, especially for hobby use if the hub tolerances are pretty much the same.
    Sep 2011
    29
    Thanks coherent and wizard!
  1. RFQ - Oldham coupling disks
    By Scot808 in forum North America RFQ's
    Last Post: 09-16-2017, 07:16 AM
  2. Oldham couplings
    By Scot808 in forum Benchtop Machines
    Last Post: 09-09-2017, 09:30 PM
  3. Replies: 7
    Last Post: 12-13-2011, 01:51 PM
  4. Lovejoy Couplers vs. Helical Couplers
    By dpgoldberg in forum DIY CNC Router Table Machines
    Last Post: 09-25-2010, 08:51 PM
  5. Diy oldham coupler
    By JBV in forum Mechanical Calculations/Engineering Design
    Last Post: 05-31-2009, 05:19 PM
