586,071 active members*
3,900 visitors online*
Results 1 to 15 of 15
    Aug 2017
    112
    Error in Drilling Cycle G83
    Hi all
    I made a program in CAM software for drilling operation in 3+2 Indexing mode.
    A strange error i am getting is G Code Error, R less than z in cycle in xy plane.
    How to solve this issue have anyone faced same problem, if yes then how you solved i t using kmotion CNC software. I am using KFLOP Board with KmotionCNC software UI.
    A screenshot is also attached with the error.
    Waiting for your kind reply
    AMIT KUMAR
    (+918952917319)
    Regards
    Amit Kumar
    May 2006
    4045
    Re: Error in Drilling Cycle G83
    Hi Amit,
    My interpretation of your G83 GCode is:
    Starting Z = 75.2
    Drill down to Z = 75.2 (this is nothing!!)
    Retract Z out to R = 14.5 (this is down not up !!)
    So as the error message is saying the R value must be above the bottom of the hole not below.
    Check your CAD system and determine why it is generating GCode like this.
    Here is a good description of G83 with a diagram
    G83 Peck Drilling Cycle (Deep Hole) for Fanuc - Helman CNC
    Regards
    TK
    http://dynomotion.com
    Aug 2017
    112
    Quote Originally Posted by TomKerekes View Post
    Hi Amit,
    Starting Z = 75.2
    Regards
    Hi Tom,
    Can you please tell me what G Code to use canned cycle (peck drilling), ?
    As I don't think G83 is supported in KMotionCNC software.
    I want to perform the above operation in 3+2 Indexing Mode.
    Waiting for your kind reply.
    Regards
    Amit Kumar
    May 2006
    4045
    Hi Amit,
    G83 should be supported. You just have to give it parameters that make sense.
    Try making one yourself by hand that drills down and retracts up to prove whether G83 works or not.
    Regards
    TK
    Jun 2004
    355
    G83 does work, however do you have your Z working the correct way?
    Z should decrease as you drill/machine into the material.
    As Tom has said, in a G83 (or any canned drilling cycle), Z should be a lower value than the retract plane (R) value.
    May 2012
    537
    G83 works fine for me.
    Pretty awesome that it caught that Tom! I've made that programming error before with a fanuc control and everything looked great until my drill crashed into the part at rapid speed lol. Nice work.
    15362
    Quote Originally Posted by amitkumar171 View Post
    Hi all
    AMIT KUMAR
    (+918952917319)
    Your program is incorrect
    G98 Return to initial point in canned cycle ( Line # 32405 Z75.2 ) The Z axes will return to this point Z75.2 when using a G98
    32420 G98G83X-10.8Y8.1 Z 75.2 This Z move is not going to move any where, this has to be a negative number to drill into your part R14.5 Q0.5F200. this whole line is incorrect, ( so how deep do you want to drill into your part )
    G99 Return to R point in canned Cycle, This would return to the R value 14.5 if it was correct, but most likely is not correct also, this has to move the drill above your work piece to give you clearance for the next move
    Mactec54
    Aug 2017
    112
    Hi mactec54,
    I am using fusion 360 for my G-Code generation and I do not get this error when I perform 3 axis operation but as soon as I shift to 5 axis (3+2 indexing), the error arises.
    I am not able to figure out if the problem is in the post processor or in the toolpath generated in fusion 360. it will be very helpful if you could help me figure this out.
    thank you
    Regards
    Amit Kumar
    15362
    Hi mactec54,
    thank you
    If you can simulate it in Fusion, and it is ok, then it would have to be in the post-processor
    Mactec54
    Aug 2017
    112
    Hi Tom,
    I made that Drilling code in fusion 360, using post processor that is attached below, and In post processor By Turning TCP on and off two different codes are generated. both are below.
    1. TCP on drilling Code generated by fusion 360 post processor
    N31220 G0 A90. C0.
    N31225 M8
    N31235 G0 X-10.8 Y-40.
    N31240 G43 Z75.2 H1
    N31250 G0 Y-30.
    N31255 G98 G83 X-10.8 Y-8.1 Z75.2 R77 Q0.5 F300.
    N31260 X10.8
    N31265 G80
    N31270 G0 Y-40.
    2. TCP off drilling Code generated by fusion 360 post processor
    N85175 G0 A90. C0.
    N85180 M8
    N85185 G0 Z40.
    N85195 G0 X-10.8 Y75.2
    N85200 G43 H1
    N85210 G0 Z30.
    N85215 G98 G83 X-10.8 Y75.2 Z8.1 R14.5 Q0.5 F300.
    N85220 X10.8
    N85225 G80
    N85230 G0 Z40.
    And i tried running both in KmotionCNC , 1st one program is giving error R less than Z in xy plane. But When i am running 1st program in controller manually inputting the coordinates its working fine, But When i press cycle start it is giving same error.
    And 2nd program of drilling that is mentioned above is not giving that error but wrong drilling in the table itself.
    How to solve that problem. If there is anything to do in the post then let me know.
    Attached Files Attached Files
    Regards
    Amit Kumar
    Jun 2004
    355
    I wonder if this is to do with plane selection.
    TCP is well beyond me, but how canned/drilling cycles work, depends on what plane is selected.
    G17 is XY, with drilling along the Z axis (default mode on most controllers)
    G18 is XZ, with drilling along the Y axis.
    G19 is YZ, with drilling along the X axis.
    Can you tell us the location of the hole, and what the start/finish heights of it should be?
    Or a screenshot of the item/holes in F360 showing the axis?
    I'm guessing you don't want to post the full CAD in public, but could you make a simple model with just the drill holes so we can see what you're trying to do?
    15362
    Hi Tom,
    N31220 G0 A90. C0.
    N31225 M8
    N31240 G43 Z75.2 H1
    N31250 G0 Y-30.
    N31260 X10.8
    N31265 G80
    N31270 G0 Y-40.
    N85175 G0 A90. C0.
    N85180 M8
    N85185 G0 Z40.
    N85200 G43 H1
    N85210 G0 Z30.
    N85220 X10.8
    N85225 G80
    N85230 G0 Z40.
    Both are incorrect, there is something wrong with your drawing, the Z axes drilling move needs to be a negative number, or where you have your Tool Zero set
    Mactec54
    Aug 2017
    112
    Hi all,
    I was talking about Multi Axis Drilling Holes in Arbitrary plane.
    Check this article is this possible in Kflop too ?
    https://www.linkedin.com/pulse/fanuc...-tim-markoski/
    This feature Tilted work planes adds extra functionality to controller other than tcp for all type of 5 axis cutting and drilling.
    if this feature can be updated to Kflop then it would be great.
    waiting for your kind reply.
    Regards
    Amit Kumar
    May 2006
    4045
    Hi Amit,
    You didn't respond to any of the previous suggestions.
    I don't think your G83 issue has anything to do with 5-axis control. All your G83 GCode doesn't make sense. Even your "good" GCode that doesn't give an error has zero depth.
    Regards
    TK
    Aug 2017
    112
    Hi Amit,
    Regards
    Hello Tom,
    i have replied to every suggestion given by you....In fact I ran my machine only after taking in your suggestions and making alterations accordingly.
    I have run the G83 code on my machine and it works perfectly fine, the only modification I had to do was to add a g18 command before it.
    Regards
    Amit Kumar
  1. Replies: 10
    Last Post: 08-23-2022, 05:37 PM
  2. Custom drilling cycle
    By imachining-6061 in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 05-13-2015, 04:59 PM
  3. peck drilling cycle
    By vance1911 in forum Okuma
    Last Post: 10-31-2013, 04:54 AM
  4. HELP drilling cycle
    By camo in forum Cincinnati CNC
    Last Post: 03-28-2012, 12:14 AM
  5. o-t series drilling cycle
    By Michael82 in forum Fanuc
    Last Post: 04-20-2008, 07:07 AM
