586,069 active members*
3,629 visitors online*
Thread: HELP NEEDED
    Mar 2018
    4
    Unhappy HELP NEEDED
    in need of some help!!!
    i have a 1998 Harrison alpher 330 plus lathe, my laptop that was running it went "pop" (it wasn't connected to the lathe at the time) so fortunately i have another
    laptop running Windows XP that run may laser.
    once i'd loaded all the soft wear on it i tested it out on the lathe, the lathe was working fine but it just said waiting to "receive program"
    but the laptop had sent it, the end result was i turned the lathe off to think about it.
    i later found out it was the COM ports that didn't match, but because i'd turned the lathe off when it was waiting to receive the program
    i now have a "PROGRAM ALARM" that i can't clear.
    any help would be much appreciated. as i have a job waiting to be done!!!
    i also have a copy of all the soft wear if any body needs a copy.
    May 2016
    526
    Re: HELP NEEDED
    pm you
  1. Replies: 8
    Last Post: 08-21-2015, 07:43 AM
  2. Replies: 0
    Last Post: 01-27-2015, 02:31 PM
  3. [ADVICE NEEDED] Z-Axis not moving - CNC builder needed
    By baodogg in forum Australia, New Zealand Club House
    Last Post: 06-03-2014, 12:42 PM
  4. Help With Project Needed - Guru Needed Please
    By cuetipper in forum DIY CNC Router Table Machines
    Last Post: 12-03-2012, 10:58 PM
  5. RFQ needed...parts needed ASAP
    By billet works in forum RFQ (Request for Quote)
    Last Post: 10-12-2011, 01:39 PM
