586,104 active members*
3,469 visitors online*
Results 1 to 15 of 15
    Aug 2004
    210
    One Dumb Question
    i no some of you may think this is a dumb question but what direction is Z- Z+ X- and X+ ????
    Jul 2005
    12177
    If you are talking about standard metalworking vertical machining centers then machine zero, also known as the machine home position, is as far to the right as possible, as far away from the operator as possible and as high as possible. This is for a machine with the X axis travelling across the position of the operator, the Y axis away from the operator and the Z axis up and down.
    With this convention -Z movement is downwards, -X movement is to the left and -Y is toward the operator.
    And now for the brain bending part...you have to pretend you are sitting on the table of the machine. Machine movement is defined as motion of the spindle relative to the table but on most VMCs it is the table that moves.
    Aug 2004
    210
    Crap i am a idiot i ment for a lathe
    Jul 2005
    12177
    Lathe??? Okay. Actually I am competing with you for being an idiot; you did mention only Z and X .
    Z as far away from the chuck as possible, normally all the way to right, is machine zero.
    X as far away from the spindle centerline as possible is machine zero.
    Z- moves tool toward chuck.
    X- moves tool toward centerline.
    In this case always use the spindle centerline as the reference for X and the spindle nose (chuck) for Z.
    Aug 2004
    210
    Thanks a lot man that sure help me now
    Dec 2006
    247
    Geof, What machine are you talking about every machine I've ever seen except for a leadwell homed out to the front left side of machine if your standing in front of it z up all the way.
    Joe
    Aug 2004
    210
    I have a busy bee lathe i installed motors on and now running mach3 turn
    Jul 2005
    12177
    Quote Originally Posted by joecnc1234 View Post
    Joe
    Which is why I said this; And now for the brain bending part...you have to pretend you are sitting on the table of the machine. Machine movement is defined as motion of the spindle relative to the table but on most VMCs it is the table that moves.
    Moving the table to the left and front puts the spindle at the home position, the back right hand corner of the table.
    When you look at it this way it does not matter whether you are on a moving table machine or a gantry machine. The home position is with Z up, normally at the tool change level, and above the right rear corner of the work area.
    Jan 2007
    355
    Ok class,
    now Geof will explain cutter radius compensation...
    (chair)
    Jul 2005
    12177
    Quote Originally Posted by Eurisko View Post
    Ok class,
    (chair)
    Are you just being a S.A. or do you really want an explanation?
    Jan 2007
    355
    No malice intended, Geof.
    I was literally LOL when I read your post, not because of anything you said, but because there are two types of machinists:
    Those that view positioning as the movement of the table & saddle,
    and those that view it as the movement of the tool.
    Almost like the cutter comp direction conundrum.
    Jul 2005
    12177
    Yes some people look at it the correct way, some don't.
    And what is the conundrum regarding cutter comp?
    Jan 2007
    355
    The cutter comp conundrum:
    If a tool (with diameter or radius comp) isn't cutting to size, many operators are confused as to what to do with the cutter compensation.
    Add? Subtract? Guess?
    Unless you're comfortable with deciphering gcode, there is an easier way to determine it. A friend told me this years ago, and it stuck :
    The cutter comp describes the tool, how much the actual tool diameter or radius differs from the programmed diameter or radius.
    A 1/2 inch end mill with a +.001 diameter comp = a .501 end mill
    A 1/2 inch end mill with a -.001 radius comp = a .498 endmill
    The program should generate the correct path for the tool that you are describing.
    Dec 2006
    247
    Geof,
    Most people call that the Cartesian coordinate system, I believe your answer stated machine zero not mcs zero which are defiantly not the same position. To lesson the confusion of your post to people who don't understand Cartesian I clearly stated most machines home position in laymans's terms.
    Dec 2006
    247
    The movement of xyz is correct as you stated but most people don't understand it the way you stated it. Thats a good reason for geometry class.
  1. Dumb Question
    By elogicca in forum Mach Mill
    Last Post: 06-11-2006, 09:28 PM
  2. Seriously dumb CAM question
    By sploo in forum Uncategorised CAM Discussion
    Last Post: 03-09-2006, 11:55 PM
  3. -OK I'll be the first to ask some dumb question-
    By Ol'Dusty in forum 80/20 TSLOTS / Other Aluminum Framing Systems
    Last Post: 11-11-2004, 03:32 PM
  4. dumb question
    By rob1215 in forum Uncategorised MetalWorking Machines
    Last Post: 06-24-2004, 06:27 PM
