586,123 active members*
3,277 visitors online*
IndustryArena Forum > CAD Software > Autodesk > R14 or replacement for windows xp——HELP NEEDED!!!
Results 1 to 8 of 8
    Mar 2018
    I built a cnc mill/engraver years ago. I set it up to run with a FET-4 controll board, from stepperword. I run K-Cam for software. I draw the files with Autocad R14 running on windows xp. The FET-4 works off of the printerport. I recently retired and have time to play, BUT a mouse built a nest in my computer and ruined it. I have another computer and loaded K-Cam up but I can not find my autocad cd or a suitable replacement. Any advice would be appreciated.
    [email protected]
    Mark
    Re: R14 or replacement for windows xp——HELP NEEDED!!!
    Draftsight is similar, and free.
    Feb 2018
    59
    dont like draftsight at all,,,,but it does 99% of autocad fucntions
    many diffrent options,, (virtual box)
    student editions
    Mar 2004
    1806
    I'll second the Draftsight. When I was a working stiff, had to use acad. I find draftsight as an easy (and might add FREE) alternative. I save my files as Rel14 dxf and have no problems with my cam software (Sheetcad)
    Art
    AKA Country Bubba (Older Than Dirt)
    Feb 2018
    59
    Ah,,r14. Memories,,,,,I think I still have my 3.5” installs,,,,,,
    just thinking outloud
    keysoftwareservice.com
    Apr 2019
    12
    Have you tried LibreCad?
    May 2019
    The Old PC may have been bad but Hard drive may still work in the new PC. It would still be XP but it may still work.
    Sep 2005
    1740
    Quote Originally Posted by DKRWoodworks View Post
    Good idea and if the old drive is not compatible with your new system, highly likely. You can buy a IDE or whatever it is adapter and run off a USB port, slow but at least you could get your old files off. Draftsight is very, very close to ACAD and it reads the files. I do not like either but it works.
  1. bearing replacement / advise needed
    By teamjnz in forum Haas Mills
    Last Post: 03-22-2018, 12:22 AM
  2. Replacement wipers needed
    By scrap maker in forum Uncategorised MetalWorking Machines
    Last Post: 10-04-2017, 06:40 PM
  3. New Motion Card Needed - NEMA23, Mach3, Windows 10, USB
    By ku3kyc in forum Controller & Computer Solutions
    Last Post: 12-19-2016, 02:54 AM
  4. K40 Main Board Replacement Options and Advice Needed.
    By peps1 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-29-2016, 05:40 AM
  5. replacement windows for VF3 door
    By wddanie in forum Haas Mills
    Last Post: 01-22-2008, 03:30 PM
