586,493 active members*
1,963 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 180i MB - changing parameter 3202 bit "NE9"
Page 1 of 2 12
Results 1 to 20 of 23
    Jun 2009
    146
    I hawe a strange problem...
    I put "1" in parameter for write. When than I want parameter "3202" to set the bit "NE9" to "0", it tells me "Write protect". I am in MDA mode. How it is that possible? On the other machine with "Fanuc Oi MC" I do the same thing, and parameter "NE9" is set to "0".
    Feb 2006
    1792
    Re: Fanuc 180i MB - changing parameter 3202 bit "NE9"
    Does the same thing happen with NE8?
    Can you change other parameters?
    May 2016
    526
    Try putting the estop in
    Jun 2009
    146
    Quote Originally Posted by sinha_nsit View Post
    No, NE8 can be changed normally. Only "NE9" does not go.
    Jun 2009
    146
    Quote Originally Posted by mbservice View Post
    I've tried it, but it does not change.
    May 2016
    526
    Silly question do you have a 9000 program active ?
    Jun 2009
    146
    No...
    May 2016
    526
    Does the parameter 3210 have a zero in it
    May 2016
    526
    3210 Password
    [Data type] 2–word axis
    This parameter sets a password for protecting program Nos. 9000 to 9999.
    When a value other than zero is set in this parameter and this value differs
    from the keyword set in parameter No.3211, bit 4 (NE9) of parameter
    No.3202 for protecting program Nos. 9000 to 9999 is automatically set to
    1. This disables the editing of program Nos. 9000 to 9999. Until the value
    set as the password is set as a keyword, NE9 cannot be set to 0 and the
    password cannot be modified.
    NOTE
    1 The state where password = 0 and password = keyword is
    referred to as the locked state. When an attempt is made to
    modify the password by MDI input operation in this state, the
    warning message “WRITE PROTECTED” is displayed to
    indicate that the password cannot be modified. When an
    attempt is made to modify the password with G10
    (programmable parameter input), P/S alarm No.231 is issued.
    2 When the value of the password is not 0, the parameter
    screen does not display the password. Care must be taken
    in setting a password.
    Jun 2009
    146
    There is no value for parameter 3210.
    May 2016
    526
    Quote Originally Posted by hartan View Post
    Type in 0
    However if it will not input it won't unlock until you
    enter correct code in 3211 to unlock
    Possibly set by manufacturer
    Jun 2009
    146
    A few months ago, I changed the last "NE9" and it changed. I have no idea why it does not work now at all. No one changed the parameters 3210 and 3211. At least not if I knew ...
    May 2016
    526
    I tested it today to eliminate it it gave the same symptoms
    Couldn't change ne9 but could change ne8 and any other parameters
    Try typing 1 in 3211 then press input and then try changing ne9 it may work
    Failing that reload parameters if you have them
    But take an sram first please
    Jun 2009
    146
    I tried it, but it does not work ...
    May 2016
    526
    You will have to reload parameters or contact Fanuc direct
    Jun 2009
    146
    Anyway thanks for now.
    Feb 2006
    1792
    If you ever get the solution, please do share.
    There is no "Back Door" to this password. You must clear all memory and reload. I even tried writing to the parameters using the ladder and it still can not be changed.
    Oct 2022
    I can crack the password of 3210. Anyone who needs it can contact me
    Quote Originally Posted by cwcnxi View Post
    can you please explain how to crack the password of 3210.
Page 1 of 2 12
  1. How can do ""manual stepper motor sizing for "rack and pinion"calculation""???
    By Medhat93 in forum Mechanical Calculations/Engineering Design
    Last Post: 03-03-2018, 01:50 AM
  2. Replies: 4
    Last Post: 05-28-2013, 09:20 PM
  3. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
