586,051 active members*
3,824 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Torchmate > Help plz ,my Accumove 3 THC can't start the job
    Aug 2016
    Hey ! i'm new here
    I have a Torchmate accumove 3
    When i run a job, the torch touch the material then go up ... and keep doing that without cutting
    I'm using Powermax 45
    Any one have an idea ?
    Aug 2011
    10
    Re: Help plz ,my Accumove 3 THC can't start the job
    If the torch makes contact with the plate and continues to slowly raise up, this means it is still detecting ohmic and trying to lift off the plate to break the circuit. Could be debri in the shield cap or you may have the shield cap screwed on too tightly, may try unscrewing the shield cap slightly to increase the clearance between the inner nozzle and shield cap.
  1. Replies: 3
    Last Post: 12-19-2015, 02:29 AM
  2. 1 start or 2 start anti-backlash nuts?
    By SpeedyDad in forum Momus Design CNC plans
    Last Post: 08-29-2011, 06:00 PM
  3. ACME rods - normal start and multi-start
    By shaffin in forum Canadian Club House
    Last Post: 12-20-2010, 02:19 PM
  4. Replies: 4
    Last Post: 01-06-2009, 05:20 PM
  5. Single start vs double start ballscrew.
    By darik in forum Linear and Rotary Motion
    Last Post: 03-22-2007, 01:53 AM
