586,117 active members*
3,444 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Chinese open/closed loop steppers
    Apr 2016
    19
    Help!
    I'm seeking for your opinion. I'm doing BF30 CNC conversion and deciding whether to get this open loop steppers:
    External EBAY LINK
    Or should i buy 2x8NM + 1x12NM closed loop steppers and drivers and power supply for them...
    External EBAY LINK
    I would like to know if closed loop system is worth 2x the cost and your opinion on this chinese stuff. Anyone got any idea if they are working as they should?
    Thank you so much!
    Best regards,
    Jure
    Feb 2018
    92
    Re: Chinese open/closed loop steppers
    I think the larger the mill and more complex the part, the more justified your decision is for using a closed loop system. I got an industrial servo set with motors and controllers run from an Acorn. If I had to do it again, I would have used clearpath motors, but only for cost.
  1. Replies: 1
    Last Post: 01-05-2018, 05:19 AM
  2. parallel to usb? + can i "convert" open loop to closed loop steppers?
    By teglberg in forum Stepper Motors / Drives
    Last Post: 08-14-2016, 03:37 AM
  3. Open Loop to Closed Loop Stepper Conversion
    By beamhome in forum Stepper Motors / Drives
    Last Post: 03-09-2014, 11:27 PM
  4. question on closed loop vs open loop (servo systems)
    By boonie in forum Servo Motors / Drives
    Last Post: 11-09-2007, 07:30 PM
  5. Lathe conversion - open loop vs closed loop
    By bhowden in forum Uncategorised MetalWorking Machines
    Last Post: 03-21-2006, 10:56 PM
