586,060 active members*
4,328 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Speed and cutting depth for aluminum??
    May 2006
    309
    What will be the right spindle speed and feeding rate for a 3mm 4 flute end mill? And which pass depth should I use for cutting in aluminum?
    Re: Speed and cutting depth for aluminum??
    Hi there,
    Based on my experience with aluminum cutting, I'd suggest you use these values.
    For 3mm 4 flute end mill
    Spindle speed: 8000rpm
    Feeding rate: 15 mm per second
    Try using a pass depth of 0.508mm
    Let me know how this works for you.
    Thanks.
  1. 2.5mm DIA 3 Flute aluminum cutting speed
    By Moodaguda in forum DIY CNC Router Table Machines
    Last Post: 08-08-2013, 07:46 AM
  2. Cut depth, Speed, and RPM
    By BodaciousBrian in forum Taig Mills / Lathes
    Last Post: 03-10-2011, 05:09 PM
  3. require low speed spindle idea for cutting Aluminum
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 09-01-2009, 08:36 AM
  4. Newbie to CNC aluminum milling feed/speed/depth/coolant, etc.
    By mrk in forum Material Machining Solutions
    Last Post: 03-30-2009, 07:51 PM
  5. Cutting speed and depth
    By MechanoMan in forum Benchtop Machines
    Last Post: 03-08-2009, 01:03 AM
