586,393 active members*
2,974 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > have STL of bas relief with undercuts, which CAM will make 4 or 5 axis toolpaths?
    Dec 2015
    171
    I would like to carve a bas relief art piece that includes undercuts . It is from a scan and in STL format.
    Can anyone offer suggestions on CAM software that actually works with such real world objects ?
    I know I could eliminate the undercuts in the model , but those results would look inferior, less dimensional.
    I'm hoping for a continuous 4 or 5 axis solution.
    Thanks!
    Apr 2004
    5742
    Re: have STL of bas relief with undercuts, which CAM will make 4 or 5 axis toolpaths?
    Do you have a 5-axis mill or router? If not, the software won't help. If you do, VisualMill Premium from Mecsoft will write the toolpaths for you. 4-axis machines usually have a rotary axis that holds the work parallel to the X (longest) axis. This is better for things that are basically cylindrical, or at least can fit within a cylinder, than for reliefs, though. Try Deskproto for continuous 4-axis toolpaths for parts like that.
    But practically speaking, especially if you're on a tight budget, carving the bulk of the relief in 3-axis mode and putting the undercuts in by hand would be the simplest solution.
    Andrew Werby
    Website
    Aug 2012
    181
    Quote Originally Posted by phucrobusl View Post
    Thanks!
    You could have a look at DESKPROTO. Version 7 just came out. It work great with huge meshes especially for artistic work like reliefs, busts/statues and jewelry and is very affordable. However it does not offer tool patches where the more then 3 Axis move at the same time. There is a free trial version and a hobbyist licence package that includes all the 4/5 axis support.
    The old GMAX offers real 5 axis machining but its a very old and difficult to use set of 3D Studio scripts to be used with a free, minimalistic version of 3D Studio that existed back in the days.
  1. Help regarding relief toolpaths
    By Daredzoni in forum Uncategorised WoodWorking Machines
    Last Post: 11-10-2014, 06:47 PM
  2. How can I make toolpaths on an imported solid
    By froya in forum Tutorials
    Last Post: 12-03-2011, 02:30 AM
  3. Replies: 2
    Last Post: 04-11-2011, 08:00 PM
  4. Can 4th axis do offaxis undercuts ?
    By lesd in forum Visual Mill
    Last Post: 12-17-2004, 01:27 PM
