586,043 active members*
3,625 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Post Processors for MC > I need help to config mastercam 2018 postprocessor with mach3 machine
Results 1 to 7 of 7
    Jun 2014
    20
    Hello, i have a home made cnc machine i useded with aspire since lot of time. now i get mastercam 2018 to try it. i have no experience with this software. i try to configure machine and post but i get an error when i try to update post fom mach3 web sit(MasterCam_MACH3B.pst). when i try to update i get this page:
    selected post were not all valid. detected post previous to mastercamx version, already updated,read only, binned post or not mp style post file.
    at this time i have a 3 axe cnc machine but I when to update to have a 5 axe.
    can anybody can help me to understand how to configure mastercam for mach3?
    Sep 2005
    1195
    Re: I need help to config mastercam 2018 postprocessor with mach3 machine
    Have done with your pp installation ? Let me know how.
    Jan 2014
    126
    What controller are you attempting to add a post processor for? I find that either the generic Fanuc post or one that I have work well for Mach 3.
    Jun 2020
    Hola, tengo el mismo problema , lograste solucionarlo ?
    Jun 2020
    Hola, yo tengo el mismo problema que el Sr. Arachid, qué postprocesador posee usted que funciona para Mach 3? Yo probé la genérica de Fanuc y no me ha funcionado. Tengo problemas con el gcode cuando genero trayectorias utilizando el cuarto eje rotatorio. Por favor , podría proporcionarme su archivo? desde ya, muchas gracias!
    Sep 2020
    Quote Originally Posted by mcardoso View Post
    Hi! Fanuc postprocessor for Mach3 is great till it gets to C axis limit. Its not going to retraction plane, and keep spinning around in material. It makes a lot of damage on workpiece surface. I wish it is easy to develop that postprocessor, but I can't find a way to do that. If you find some solution, please contact me. Thanks!
    Oct 2020
    9
    Hello I have a homemade 3 axis router cnc, and I am using Mastercam 2018 to generate G-code and import it to Mach3. My toolpaths turn into circles when imported into Mach3. I understand that this problem is related to my post processor. Could anyone help me with information on what post processor I should be using to communicate with Mach3?
  1. Mach3 postprocessor for Mastercam X6
    By rdpdo in forum Post Processors for MC
    Last Post: 11-18-2018, 09:03 PM
  2. Mastercam X4 postprocessor for ISEL CPM 2018
    By TEH in forum Post Processors for MC
    Last Post: 04-08-2018, 11:04 PM
  3. Postprocessor Powermill 2018 for mach3?
    By Swets in forum Post Processor Files
    Last Post: 01-18-2018, 12:09 AM
  4. Mastercam 2018 Machine Definition Menu Management
    By dkrenfrow in forum Mastercam
    Last Post: 08-24-2017, 07:43 AM
