586,060 active members*
4,191 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki Mills > Need Help Loading Tools - MV80, Fanuc 11M
    Apr 2016
    5
    Exclamation Need Help Loading Tools - MV80, Fanuc 11M
    We just got a MV80 into the shop and put power to it. I am the one to get it running and have all of the manuals, but my experience is all on the Fadal side and a little on the Mori lathe with a Moric control. I have loaded the first program, got my fixture offset but cannot figure out what the manual is telling me to do to set the tools in the magazine and then to set the tool offset.
    I get that tool 00 is the active tool and that calling tools is somewhat of a random association in the magazine depending on where the magazine is in its rotation when tools are needed. But how do I set the tool's length offset? And how do I use MDI to call up and load the tools? Is there a procedure out there that is more "English" than this Mori manual?
    I assume "registering tool data" means "entering tool offsets". I cant tell if I need to do procedure one and procedure two or if they are "option 1" and "option 2". (p.155 - 160 of the MV-80 machine manual). And why would you have 40 magazines? There is only one magazine with 40 pots.
    I am SO close to running this simple program, but I have no idea how to get over this one. Not even close to the Fadal from what I can tell.
    Basically I'm wondering: how do you guys do it?
    Apr 2016
    5
    Re: Need Help Loading Tools - MV80, Fanuc 11M
    OK, I figured out that a "magazine" is a "pot". That means that a magazine is a separate thing from the tool, unlike the Fadal where they are one in the same. This makes sense because of the random placing of the tools in the pots.
    Well that's settled. Now how do I set tools? How are you guys doing it?
  1. Replies: 12
    Last Post: 05-04-2017, 12:21 AM
  2. Specialist notes about the loading and unloading of engraving tools
    By Tongxing in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-21-2015, 02:32 AM
  3. HSMXpress problem loading turning tools
    By NMGMarques in forum Autodesk CAM
    Last Post: 06-29-2015, 02:13 PM
  4. Bridgeport 1000/22 Loading Tools
    By BetaBob in forum Bridgeport / Hardinge Mills
    Last Post: 12-11-2010, 03:00 PM
