586,096 active members*
3,772 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Configuring ST-V2 BOB for 0-10V analogue control Mach3
    I am retrofitting my cnc mill, and finally I have everything wired up (I hope), but I need some help for configuration for spindle control.
    I run a 0.44 kw DC motor (stock) that is powered with HX-SXPWM-A Pulse-Width DC motor speed controller Digital AC180V-260V DC180V.
    I can start/run the spindle with potentiometer that was already attached to the speed controller, but I want to control it through software.
    I am using a common 5axis china bob, ST-V2, with one relay. I took pictures of how is everything wired there (nothing too fancy, I am not an electrician or have too much experience in this field) with a help from a friend.
    How should I set up the ports/pins, motor outputs, input/output signals and spindle setup? what pwm freq and minimum pwm to use? And did I wire up everything I need?
    While searching, I found that I should move the jumper on board for P17 (will have to try that too) for spindle control (I didnt touch anything there).
    And also, one strange thing (that concerns me most) is when I start motor speed controller manually, the Z axis moves a bit in one or another direction, even if steppers are not receiving any command from me. I believe I used proper shielded cables on everything that was necessary,
    and could that be happening from inadequate port/pinc configuration?
    Attached Thumbnails Attached Thumbnails fr_1328.jpg   fr_1329.jpg   fr_1330.jpg   fr_1331.jpg
    Re: Configuring ST-V2 BOB for 0-10V analogue control Mach3
    software setup
    Attached Thumbnails Attached Thumbnails fr_1335_size640.jpg   fr_1336_size640.jpg   fr_1337_size640.jpg   fr_1338_size640.jpg
    and bit more detailed hardware pictures. did I miss to connect/wire something, or theres something wrong with the mach3 setup?
    Attached Thumbnails Attached Thumbnails fr_1341_size640.jpg   fr_1342_size640.jpg   fr_1343_size640.jpg   fr_1344_size640.jpg
  1. help configuring MACH3/ethernet smoothstepper with non-machining application
    By ben1272 in forum Machines running Mach Software
    Last Post: 06-02-2015, 05:15 PM
  2. Configuring Mach 3 with my control kit.
    By JackWilliam in forum Mach Software (ArtSoft software)
    Last Post: 12-12-2012, 11:27 AM
  3. Configuring Mach3 for KG5050
    By Chuck Hammond in forum K2CNC
    Last Post: 09-09-2012, 07:39 PM
  4. Configuring Mach3
    By hub in forum Mach Mill
    Last Post: 05-16-2011, 04:48 PM
  5. configuring Mach 3 for twin X axis stepper motor control
    By Alex2005 in forum Mach Software (ArtSoft software)
    Last Post: 03-07-2008, 09:15 AM
