586,067 active members*
5,273 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > "PROGRAM LOAD FAILED DATA ERROR" Fanuc 160i pc/windows interface Cinci CL-6 laser
    Mar 2009
    8
    Hello. I was hoping to get some help here seeing as though everybody else I have talked to has been
    somewhat stumped on what I am assuming should be a simple fix.
    My problem involves a used cinci CL-6 Fanuc 160i laser system.
    After sorting through various issues I have landed on this and have been stuck for a week.
    After the computer boots up and the cinci/fanuc interface loads, I go through the process
    of opening a cnc file. Then after that I attempt to LOAD CNC. At this point a windows style
    box opens up with the message "LOAD PROGRAM FAILED DATA ERROR". I am at a loss
    as to why this is. This only occurs from programs generated by our cinci nesting software.
    Pre-loaded files in the computers utilities folder (test squares, simple circle etc.) load without
    issue. The current theory is that the HDD on the controller is somehow corrupted and needs
    to re-imaged. Any help would be greatly appreciated.
    Allan
    Mar 2009
    8
    Re: "PROGRAM LOAD FAILED DATA ERROR" Fanuc 160i pc/windows interface Cinci CL-6 lase
    Problem solved. Thanks.
  1. Mazak Data Transfer on Windows 7 "XP" mode?
    By pontiacg5 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-05-2019, 03:50 PM
  2. Replies: 5
    Last Post: 05-24-2017, 10:37 PM
  3. Program "Load" and fixture offset questions.
    By Fighter in forum Dynapath
    Last Post: 06-29-2011, 12:58 AM
  4. "Runtime error 9 - subscript out of range" on Techno CNC interface
    By zhoudfoster in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-26-2009, 04:57 AM
  5. "wrong program data" when file transfer????
    By spock in forum Bridgeport / Hardinge Mills
    Last Post: 07-28-2008, 11:59 PM
