586,108 active members*
3,052 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Need help - wiring PlanetCNC Mk3/4 with 1.5kw VFD
    I'm setting up a Routakit with a 1.5kw VFD, running the PlanetCNC Mk3/4 controller, but I'm not certain how to wire it so I can control the spindle from my program (On/Off and spindle speed).
    Any help would be greatly appreciated,
    Don
    It's all about the Cool Factor!
    Billet Works Designs
    Apr 2003
    540
    Re: Need help - wiring PlanetCNC Mk3/4 with 1.5kw VFD
    It depends on your VFD and hardware & software. Simplest id If you have a Huanyang VFD there is a free plugin for Mach 3 or UCCNC. If that's the case a cheap USB to RS485 (less than $10) converter and 2 wires will control the spindle for you. If not then it depends on your hardware/breakout board. Analog PWM control may be an option if your board has the required outputs. Another option depends on your VFD. If it has the optional MODBUS the spinddle can be controlled using the MODBUS connections.
    Muhammad_Haroon Guest
    I've cnc router. Everything works fine but spindle is not rotating. Click image for larger version.
  1. Spindle synchronisation with PlanetCNC TNG
    By PlanetCNC in forum PlanetCNC
    Last Post: 09-08-2019, 08:49 AM
  2. Issues with PlanetCNC TNG
    By nucutza in forum PlanetCNC
    Last Post: 11-19-2017, 10:23 AM
  3. Planetcnc controller
    By go47f in forum PlanetCNC
    Last Post: 10-06-2017, 05:14 PM
  4. PlanetCNC DIY Controllers and TNG
    By ccandiotes in forum PlanetCNC
    Last Post: 08-01-2017, 10:28 AM
  5. PlanetCNC is on CNCZONE!!
    Last Post: 03-07-2017, 12:01 PM
