586,094 active members*
4,177 visitors online*
Thread: Losing power
    Mar 2018
    Losing power
    Hello,
    I have recently purchased a chinese Laser CNC with a "150W" RECI tube. (150W in chinese means 130W nominal power with 149 peak power)
    All was ok until a few days ago when I noticed a sudden loss in the current drawn by the tube.
    If until know I was running the machine at 60% (at 28mA) now I have only 14mA or so at the same 60% and the cutting is poor.
    The water temp is 18degC at first then it goes up to 20degC.
    If I let the machine off for a few hours and then start it again I have the power restored but only to lose it after 5-10 min.
    Any help will be much appreciated.
    Thank you,
    Mar 2018
    Re: Losing power
    Recent update...
    Lost almost all power even at cold start.
    Ameter shows 28mA but beam only scratches the surface.
    Re: Losing power
    Hi there,
    There could have been a small or slow leak in the tube causing the release of CO2 gas. The power supply could have also suffered from an electrical issue.
    You can check the in-going power and make sure that you have a good neutral connection.
    From experience, the issue is not the power supply but the power coming into the power supply that causes the problem. There is a chance that the power coming in is good, but there is a loose neutral connection. This is the neutral connection that runs all the way back to the panel in your home/workshop.
    Try this trouble shoot and let me know how it worked.
    Mar 2018
    Re: Losing power
    Hi, thank you for your reply,
    The problem seem to be fixed now, not sure what mattered.
    I have cleaned and reinstalled the tube (it was dusty)
    I have changed the water in the cooler.
    Realigned and cleaned the mirrors
    Tought of installing a UPS
    It runs ok now, the water temperature is not an issue anymore.
    The neutral is ok-ish i think. Good to know though.
    A thing I have discovered and it took me a while to figure it out:
    When running at 10mm/s and lower The laser is running at the MinPower setting whatever the MaxPower is.
    I was running it with 20% Min and 60% Max so it seemed to draw only 10mA (normal for 20%) at 60%.
    Thank you again
    Apr 2018
    20
    Re: Losing power
    If you need replacement can contact me skype:jason1982918 or [email protected]
  1. HELP LOSING POWER / 80watt C02
    By sehio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-09-2017, 11:44 AM
  2. xy losing 0 when i power off and on
    By mark.a in forum LaserCut
    Last Post: 02-17-2016, 01:33 PM
  3. New K40 losing power in 3-5 seconds
    By chils41 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-20-2015, 12:32 PM
  4. Losing Laser Power
    By belin in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-02-2014, 12:14 PM
  5. Keep Losing power too my system.
    By CROSSHATCH in forum CNC Machine Related Electronics
    Last Post: 02-27-2008, 02:23 AM
