586,051 active members*
3,870 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Help sourcing hard to find parts for diy CNC build
Results 1 to 14 of 14
    Mar 2017
    926
    Does anyone know where I can find a 1/4" to 15mm motor coupling? I ordered some on eBay but the vendor sent me 9mm x 15mm couplings and then told me they don't have any 1/4" x 15mm ones in stock. I can't find any other vendors offering this size...
    If I can't buy them, is a diy coupling an option? It seems like it would be a simple case of finding the right size drill bits and adding a couple of set screws. Is there more to it than that?
    My other options would be using pulleys or using an intermediate shaft as I can easily find 1/4" x 12mm and 12mm x 15mm couplings but neither of those are ideal...
    Dec 2013
    5717
    Re: Help sourcing hard to find parts for diy CNC build
    Build a 9mm x 1/4 bushing maybe? That's what I would do, a quick job in a lathe if you have one.
    Jim Dawson
    Sandy, Oregon, USA
    Mar 2017
    926
    Someone just sent me an email with a place. If anyone else is looking for unusual size couplings, this is the place:
    NBK Japan MJC-30-RD 1/4 inch to 15mm Jaw-type Flexible Coupling
    Parts for larger ball screws can get really expensive.....
    McMaster Carr 6408K series
    Mar 2017
    926
    Would you do that over making a direct coupling on a drill press? I.e. Drilling a 1/4" hole through a steel round bar and then enlarging the hole on one side to 15mm and then drilling small holes for set screws.
    I don't have a lathe although I have been thinking of buying a small one lately. It's one of those things I have a need for occasionally but it never seems to be enough to justify the purchase. I can't decide if those small benchtop models are good enough to be worth it...
    Mar 2017
    926
    I keep forgetting about McMaster. I was just looking at their site again and they have a lot of interesting parts for a CNC build. I like the look of their "ultra flat heavy duty tables".
    Apr 2004
    5737
    You can use a solid coupler if everything is really lined up perfectly. If not, rotation with a little eccentricity will snap the shaft off your motor. Here's more information about it than you probably want to read: Criteria For Power Transmission Couplings - SDP/SI You can get Oldham style couplers (the kind with a rubber piece in between) that fit inch or metric shafts from the same site; just order one from the inch catalog and one from the metric catalog - the rubber "spiders" fit both.
    Andrew Werby
    Website
    Dec 2017
    77
    I'm learning as I go here, particularly from that website you just linked - it's great! So, correct me if I'm wrong on a technicality. The Oldham coupling is the type with full diameter slots that attach the inner element to the hubs. Whereas a jaw coupling is the one with an element that fills the spaces between alternating radial parts on the hubs. The term I've heard a lot is "spider coupling," but I guess that's ambiguous.
    Feb 2007
    4553
    When searching eBay look for 6.35mm X 15mm, you will find many vendors.
    https://www.ebay.com/itm/D30L42-Flex...AAAOSwfxJZ6oN~
    Jeff...
    Quote Originally Posted by Goemon View Post
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Mar 2017
    926
    Quote Originally Posted by jalessi View Post
    Jeff...
    Not many. Just a few and at least two of them don't have what they are advertising. I ordered from them and, as I said, one sent me the wrong size and then said they didn't actually have the 6.35mm x 15mm. The other just cancelled my order and said they didn't have it. For reasons I will never understand or accept, both vendors are still advertising the same 6.35mm x 15mm coupling that they don't have...
    The link you posted is a vendor in China. I don't order anything direct from Chinese vendors. They take forever and I have zero trust left for any vendors over there. Too many bad experiences.
    Mar 2017
    926
    Quote Originally Posted by awerby View Post
    I assume that is why some use flexible couplings. I wondered about that as it sounded like a recipe for backlash.
    My emergency diy coupling will be my spare straight shank tool holders. I have some with a 1/2" shank so I could just buy the right size collet to create an appropriately centered coupling for odd sizes.
    I might have to do something diy for my new Z axis ball screw. I misread the specs and accidentally bought a 38mm screw with a 63mm barrel ball nut.... Somehow, I don't think anyone expected to drive it with a nema 23 with a 1/4" shaft....
    Nov 2007
    I have bought 14mm couplers from RoverCNC.com. Good quality and reasonable prices. Several sizes available. John A.
    Sent from my iPad using Tapatalk
    Feb 2007
    4553
    Purchase these and drill the 10mm side out to 15mm, it's easy to accomplish as long as you shim the gap before drilling.
    https://www.ebay.com/itm/3Pcs-6-35x10mm-CNC-Stepper-Motor-Jaw-Shaft-Coupler-6-35mm-to-10mm-Flexible-Jaw-S/222894434020?hash=item33e58b26e4:g8sAAOSwUQlas9e0
    Jeff...
    Nov 2011
    137
    I have ( I think there called) lovejoy couplings on mine stepper side is 1/4,acme thread side is 7/16.Comes with a set screw for each side and a very solid rubber connector between then the perfect answer for a motor that is not perfectly aligned with the rod,when I installed mine I pushed the acme lead screw tight with a bearing and I have about a 1/2 space on the outer side so if i need to tighten it up I can...gets rid of backlash......they com in different sizes real cheap got mine from Granger.....
  1. Help, sourcing parts for LTT ILS III?
    By Pplug in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-01-2021, 12:34 PM
  2. DIY BUILD. WHERE TO FIND PARTS IN CANADA
    By Mikemann55 in forum Want To Buy...Need help!
    Last Post: 01-24-2017, 05:00 AM
  3. partial 80/20 build using some easy to find parts
    By RNation0001 in forum DIY CNC Router Table Machines
    Last Post: 05-18-2014, 04:08 AM
  4. ...to find a machine or someone to build parts
    By dabckid in forum Want To Buy...Need help!
    Last Post: 05-31-2008, 09:25 AM
  5. Sourcing Parts
    By SPEEDRE in forum CNC Machine Related Electronics
    Last Post: 04-03-2008, 03:13 AM
