586,121 active members*
3,643 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Adv. Posting auger on/off
Page 1 of 2 12
Results 1 to 20 of 22
    Apr 2009
    3376
    Trying to have advanced posting tab with the ability to turn chip auger on or off for pocketing routine
    Can get the tab to show up in the wizard,but posting does not acknowledge it
    So I figure something on line 3 or 2001 is wrong
    any help appreciated
    3. Tool change
    n,spindle_off
    n,"M09"
    n,program_block_1
    n,rapid_move,incremental_coord,"G28","Z0."
    n,optional_stop
    "(NEXT CUT - NEXT TOOL)"
    system_comment
    feature_name_comment
    n,t,"M06"
    n,rapid_move,absolute_coord,work_coord,force_x,xr, force_y,yr,rotary_xyr_angle,,s,spindle_on
    n,rapid_move,length_offset,coolant_on
    output_rotary_angle
    2001. Program Block 1 - Output code M33 or M31
    code = MILL_GetUserSelectComboVariable(0) 'Get which item is selected for COMBO_BOX 1
    '0 = M33, 1 = M31
    'ans = MsgBox("code is " & code) 'Display message box with value of code
    Select Case code 'Output the correct string based on user selection
    Case 0
    MILL_SetReturnString(" M31”)
    Case 1
    MILL_SetReturnString(" M33”)
    End Select
    Apr 2009
    3376
    Re: Adv. Posting auger on/off
    here is the custom file to put the tab in the wizard
    COMBO_BOX,1,M33,M31
    TEXT_LABEL,1,Set Auger Mode M33 off
    DEFAULT_COMBO_INDEX,2,3
    Apr 2009
    3376
    Well,we lost SBC a while back to M Cam,,,he bought a 5 axis Haas that came with it I believe,,,anyhow,huge lost to the forum
    General,do you see something that looks wrong ?
    Jun 2008
    1838
    Quote Originally Posted by jrmach View Post
    I agree, great loss to the community
    Anyway, what I have works here although all I could see was the last line of the custom file, so try out the following and if it works for you as well then great if not back to the headache pills
    Program block setup is :-
    2001. Program Block 1 - Output a M31 or M33 depending on what is selected in the posting page
    code = MILL_GetUserSelectComboVariable(0) 'Get which item is selected for COMBO_BOX 1 '0 = M31, 1 = M33
    Select Case code 'Ouput the correct string based on user selection
    Case 0
    MILL_SetReturnString(" M31")
    Case 1
    MILL_SetReturnString(" M33")
    End Select
    Custom file is :-
    COMBO_BOX,1,M31,M33
    DEFAULT_COMBO_INDEX,1,1
    TEXT_LABEL,1,Select Auger M33 Off
    Like I said, works here, hope it helps
    Regards
    Rob
    Apr 2009
    3376
    headache pills,,need a new prescription
    just does not want to output a M31 or M33
    Jun 2008
    1838
    What are you saving the Combo Box file out as into your Post Processor Library ??
    It needs to be like this :-
    Your PP name followed by the extension .CustomPocket, example jrmachHAAS.MillPst.CustomPocket
    If you wanted something to have an Advanced Post page on a Profile operation then the .CustomPocket would be a separate Combo Box file of .CustomProfile.
    Hope that helps a bit, I`m pretty rusty on this stuff, must be around 4/5 years since I played around with it
    Regards
    Rob
    Jun 2008
    1838
    Just for your information, I have managed to do it with a "shared" Custom file and if it helps you any here are all the files that work together, the BobCAD Pocket file with Profile finish, the Advanced Post Processor and the Custom milling file. The Pocket file was done in V28 Build 2067, let me know if you have an earlier version/build and I will do a BobCAD file in V26 for you, it all outputs fine here so I don`t see any reason why it wouldn`t work at your end
    Have fun
    Regards
    Rob
    Apr 2009
    3376
    Rob,,,when I put everything in my PP,,it don't work
    Perhaps you could look at my PP and try it ?
    This is a untouched copy of my PP
    Attached Files Attached Files
    Jun 2008
    1838
    James
    It looks like your PP is not an advanced posting engine one, I am working on a duplicate of your PP that works and has all the tweaks etc
    Could be a couple of hours or more depending on what/how many changes I will need to make
    Regards
    Rob
    Jun 2008
    1838
    James
    Phew, don`t want to have to do that too many times
    Attached is a modifed version of your original PP, I assume that it does work for your HAAS machine, if so then it should continue to do so but please, please double check all your code for at least the first few jobs you do, I have been doing lots and lots of typing and it is very easy to do a little "typo" here and there
    I have slightly altered the name of the PP and the CustomMilling file so that it shouldn`t interfere with any of your existing files in your PP library, you should just be able to copy and paste into the Library and then in your job select the new PP as the default PP
    Hope this works for you this time, I have done 3 different Combo Boxes in the CustomMilling file so you can see how the numbers (Particularly the Index ones) are laid out, all you need to do is place the call out line where you want it in the PP, I have left all 3 in there so just do a simple pocket with a profile finish and have a play changing the selections around to get the hang of it all
    Because it is a "Shared" CustomMillling file it will be available on all 2 axis through 4 axis features so it may require some careful positioning of the call up lines to avoid things being called up where they are not wanted
    If you only want the single M31/M33 option then you can easily change the CustomMilling file to a CustomPocket file just by doing a re-name
    Fingers crossed, enjoy
    Regards
    Rob
    Apr 2009
    3376
    TY
    At least it showed up in code
    Not sure about turning off when I want
    after a few real life jobs I'LL know
    wtf,,,,my PP is ancient?
    "It looks like your PP is not an advanced posting engine one"
    no idea what you talking about
    Jun 2008
    1838
    TY
    Glad it`s working for you, all`s well that ends well
    Don`t know if your PP is old, it does seem to be a bit jumbled up but it does work so "ain`t broke so don`t fix it", the PP that I modified for you is an old V26 one that was known to work with the Advanced Posting so that is why I used it, originally uploaded by Al
    No all PPs will accept the advanced posting, I have no idea why, something embedded in them I would expect ? ? ?
    Regards
    Rob
    Apr 2009
    3376
    Just to be clear,,the very last PP that you got to work was mine that I uploaded,,correct ?
    or
    it is a modified V26 ?
    Jun 2008
    1838
    or
    Modified V26 with all the stuff from your PP added to it to bring it up to the same as the one you uploaded and with the ability to do the Advance Posting so it will work exactly as your PP did plus what you wanted
    Apr 2009
    3376
    gotcha,,,,
    you come Stateside,Idaho to be specific,,,dinner on me Rob
    Jun 2008
    1838
    gotcha,,,,
    If I ever get over there I will certainly take up your offer, just as long as there is a nice baked potato with the steak
    Looked Idaho up, looks like a great place to live, all that clean,fresh air, lucky guy
    Regards
    Rob
    Apr 2009
    3376
    you can have Lobster too,,,I really appreciate your time
    Jun 2008
    1838
    You are welcome
    Apr 2008
    1577
    Hey guys! I poke my head in every now and then but I don't get near the time I once had to participate. I assure you the loss is mine and I very much miss this forum and the old BCC forum. I could write encyclopedias with the knowledge milked from all of you I also still use BobCAD (V29) despite having MC. I still make a lot of the same parts (or revisions of them) that I've been making with BobCAD for over 10 years now. Every new version gets better and I find ways to save time on old files all the time. And it's much faster to program a revision with BobCAD than start all over in MC. I'm running these parts today - programmed in V26 - and I managed to shave 3 minutes off the final operation with some V29 enhancements and tweaks.
    It's funny that I ran into this thread today because I was thinking of this exact problem a few days ago when I reprogrammed this part. I made multiple tweaks and I had to keep adding the M31 code manually each time to move the plastic shavings (they pile up fast). I remember jrmach made a thread on this some time ago but I wasn't able to follow up. Now I need it and here it is! This community continues to be a valuable asset and you guys have always been a part of it as long as I have been here. I am blessed to be a part of it! Nice work Rob, I'm going to hack this into my post and I will upload the result if I get it working, thank you!
    jrmach, I think you were right there and I think I might see the problem. I'll look at your post as well for my own sake, I'm rusty on the VBScript and was never that great with it to begin with I'm glad to see you are all still well and active and I would love a meetup with all of you, we'll have to fight it out on who is buying beers and dinner
    Mastercam X9/2017 Multiaxis for SolidWorks - Bobcad V29 3ax Pro 4ax Std.
    Jun 2008
    1838
    Hi SBC
    Really nice to hear you are still going strong, call in more often if you can
    Reckon James is buying the dinner, as for the beers, well as I am not allowed to drink anymore that would be a bit rough but I suppose I could pay a round or two just to be sociable
    Really would be nice if we were able to all meet up one day, getting the time and of course the travel costs from the UK might cause a couple of problems and the fact that I haven`t had a Passport since 1999
    I have stopped at V28, V29 and especially V30 are now so "resource hungry" that none of my 4 seats computers can run BC V30 fast enough now and to update all the hardware my PC builder reckons it would cost me around £3500 GBP per seat, they downloaded the V30 software and ran various tests on several pretty high end computers they use and that was what they came up with
    That is somewhere around $4900 USD which comes out to about $19600 USD for the lot and that`s before I actually buy the V30 upgrade so V28 it is for me unless I win the Lottery
    Anyway, enough of that, just nice to see you on here again.
    Regards
Page 1 of 2 12
  1. problem posting MCX5 posting to Cimco edit v5.6
    By cdmmachining in forum Mastercam
    Last Post: 05-10-2012, 02:09 PM
  2. Chip auger
    By l u k e in forum Haas Mills
    Last Post: 05-26-2011, 10:02 PM
  3. Chip auger
    By br1 in forum Haas Mills
    Last Post: 09-11-2008, 03:15 PM
  4. Chip auger help
    By Janos in forum Uncategorised MetalWorking Machines
    Last Post: 01-29-2007, 04:40 PM
