586,108 active members*
2,982 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > 2.2kw water cooled spindle VFD wiring
    Feb 2018
    I have a Chinese single phase VFD powering a 2.2 watercooled spindle. I have a basic 5 axis Mach 3 breakout board. What connections do I need to make to which terminals to use Mach3 to turn the spindle on and control the spindle speed? It didn’t come with directions.
    Any help would be appreciated.
    24221
    Re: 2.2kw water cooled spindle VFD wiring
    Plenty of manuals out there, search Huanyang VFD Manual.
    You will also need a service Earth ground.
    Al.
    Albert E.
  1. Crazy Idea - converting Air Cooled spindle to Water Cooled
    By BanduraMaker in forum DIY CNC Router Table Machines
    Last Post: 01-20-2018, 02:29 AM
  2. 4kw Chinese water cooled spindle wiring to VFD Need Help
    By cnccutting in forum Spindles / VFD
    Last Post: 02-22-2017, 05:11 AM
  3. Water pump for water cooled spindle
    By bballish in forum DIY CNC Router Table Machines
    Last Post: 03-01-2016, 02:40 AM
  4. Water cooled 2.2 KW Spindle water fitting
    By dfmiller in forum DIY CNC Router Table Machines
    Last Post: 11-26-2013, 06:21 AM
  5. water cooled spindle vs air cooled
    By ken2010 in forum Chinese Machines
    Last Post: 10-21-2013, 06:03 PM
