CW-5000 Water Chiller(AC110V or 220V), The price is $499USD
this unit controls the temperature of the laser tube cooling water and prevents laser operation
if water flow fails or chiller is left off.
Compact design with ±0.3'C temperature accuracy
Compressor delay circuit, over-current protection
Over-heat temperature alert, water flow protection
CE certified
Specification
Cooling Power: 692W
BTU: 2361 BTU / h
Input power: AC 220V, 50Hz
Current; 2.1A
Compressor power: 3/8HP, 305Watt
Freon: R134a
Pump power: 30W
Lift (cut off) : 10m (33ft)
Rate: 10L/min, 158GPH
Ambient Temp.: ≤ 35 ' c
Chilled Water Temp. 8~30'C
Dimension:550×280×430mm
Peak Sign Inc.
485 Finchdene Square Unit # 1, Scarborough Ontario M1X 1B7, Canada
Phone: 647-873-6083
[email protected], [email protected]
