586,301 active members*
3,921 visitors online*
Results 1 to 11 of 11
    Oct 2007
    23
    New Machine - New Problems: e stop issue
    New machine. FLA 100. New Chinese spindle(Hyunyang 2.2kw). I'm getting an e stop almost as soon as the tool starts cutting. I've heard these cheap spindles and VFD's are noise factories too.
    The error is "external e stop requested". I've disconnected the e stop switch and set the e stop to active low to try and isolate the issue. This made zero difference. Is the problem really noise on the e stop pin, or could it be noise from limit switch wiring as well? Would noise on a limit switch line not cause a false limit trigger?
    I have made a moderate investment (for me) in this machine and in time putting it all together. Getting frustrated! Thank you in advance!
    Sent from my SAMSUNG-SM-N920A using Tapatalk
    Apr 2004
    5740
    Re: New Machine - New Problems: e stop issue
    Is there any shielding on the cable between the VFD and the spindle? That can be a major source of RFI. Most people say to use a braided metallic shield and ground it on one end only (usually the spindle end) although there are those who say you can ground both ends.
    Andrew Werby
    Website
    24221
    Do you have proper earth grounding on the machine and to the frame of the spindle?
    Also the various parts of the machine frame bonded to earth?
    Al.
    Albert E.
    Oct 2007
    23
    Quote Originally Posted by awerby View Post
    No. The VFD cable is not shielded. I may order some shielded cable and replace it. I find it odd that I'm getting false e stops and the FVD cable is a long ways from the e stop wiring.
    Oct 2007
    23
    Al.
    The machine frame is grounded to mains ground. The spindle mount is aluminum and has continuity through the frame, but that does go through the linear motion bearings.
    I'm also using the spindle mount for the probe wire attachment point, as this has continuity through the tool. I could remove this and see if that may be where the noise is being introduced.
    Oct 2007
    23
    Quote Originally Posted by lowslo View Post
    I ran a small part by zeroing the tool and then removing the probe connection from the spindle mount. E stop within a minute. Not to say this isn't how the noise is being introduced, but there was no physical connection of the probe wire to the machine.
    Apr 2004
    5740
    You don't need a physical connection; RFI can travel through the air. You also don't need to replace your existing cables, just slip a braided shield over the whole bundle that goes from the VFD to the spindle. Like this stuff: https://www.cableorganizer.com/metal-braided-sleeving/
    Andrew Werby
    Website
    Oct 2007
    23
    Thanks for everyones input and assistance. It's wierd that it will cut air without issue, but as soon as the tool touches the workpiece it triggers an e stop.
    24221
    You should Never rely on earth GND through linear bearings, a proper earth conductor is needed.
    Not to mention the fact that the bearings can receive damage if a heavy GNF fault occurs
    Al.
    Albert E.
    DIsable the limits and see if it still does it.
    Oct 2007
    23
    How do you do it Gerry?
    That was it. AGAIN, you have helped me.
    A big thank you to all those that helped me narrow it down and make suggestions. I guess I need to rework my limit switch wiring and harden it against noise better. It's strange that noise on the limit switch wiring was being interpreted as an e stop request.
    I plan on upgrading some other potential ground issues that have been pointed out and installing a secondary ground rod for the low voltage side.
    Thank you all once again
    Ryan
  1. Problems with Emergency Stop/Stop function.
    By MrEmo in forum PlanetCNC
    Last Post: 10-19-2021, 10:47 AM
  2. E-Stop issue.
    By starnw50 in forum Mach Software (ArtSoft software)
    Last Post: 05-18-2015, 09:42 PM
  3. Machine stop / Spindle Stop with a Dwell
    By yaji63 in forum Fanuc
    Last Post: 02-16-2014, 06:49 PM
  4. Random Stopping - E-Stop Issue
    By EvanZ in forum DIY CNC Router Table Machines
    Last Post: 11-07-2008, 08:57 PM
