Reset Buffer in Remote/Tape mode (drip feeding) after a feed hold
Is there a simple way while feed holding a drip feed to reset the lines of code that are buffered at the machine. A machine reset does not clear the buffer. I have figured a way of doing it that is getting me by, but seems much too complicated to keep it simple for all operators. I have to hit feed hold, close down DNC software, hit cylce start at machine, this causes LSK error on machine because software is no longer connected. Then I hit reset at the machine, but this still does not clear the buffer, just the LSK error, then switch to auto and run a tool change position program. Go back to remote mode and it is finally gone. Too many steps! Is there a paremeter which clears buffer on a reset in the remote/tape mode.
Fanuc 18 control
Chad
Multi-Tasking Machining - Customer savings, and shorter lead times!
www.northernmachininginc.com
