586,058 active members*
4,361 visitors online*
IndustryArena Forum > CNC Electronics > Phase Converters > Need help! Balance voltage rotary converter motor 7.5 hp
Page 1 of 4 123
Results 1 to 20 of 66
    Apr 2018
    43
    Please help me with my rotary converter motor 7.5 hp! I’m following the procedure in this document http://www.practicalmachinist.com/FitchWConverter.pdf but I can’t balance the voltage. My L1 and L2 are stable 117 and 120 (measured with the ground). I don’t know why, but I need to put at lease 100 uf of capacitor for the Cp (between A and C / A=T1, C=T3) to get a decent voltage measurement between the leg and the reading is crazy Vab = 230 Vac = 285 Vbc = 462. When I put more capacitors Cp at 168 uf I get Vab = 229 Bac168 Vbc = 385. I just don’t know what to do to tune my legs and balance the voltage of my rotary conventer motor 7.5 hp. Thanks in advance for your support.
    Mar 2017
    314
    Re: Need help! Balance voltage rotary converter motor 7.5 hp
    I think you have your leads wrong on your motor. Caps wont fix that.
    Dec 2013
    5717
    What generaldisarray said, swap the motor leads, at the A and C connection points and see what that does. And check it under load, I used 3 stove top elements as a resistive load for initial setup. Then did the final tuning when running the lathe. I had to play around with my connections a bit to get it to balance. Unloaded T1-T3 (A-C) is about 256, but loaded it's 240,240,239 (when I checked it today). I also used the FitchW pdf as the basis for my design.
    EDIT: Are you sure you have the motor properly wired for 230V? T1 1-7, T2 2-8, T3 3-9, and 4,5,6 connected together.
    Jim Dawson
    Sandy, Oregon, USA
    Mar 2017
    314
    Thats what I meant, It sounds like the leads are mixed-up on the idler.
    A converter with zero caps is not that far out of balance.
    Apr 2018
    43
    Thanks for your comments. I just swap yellow and red, still the same results. As you can see on the pictures, there is only 3 wires coming out of my motor. I don't know which one is T1 or T2 or T3 and I though it was not very important... I guess I was wrong
    Here are my connection to the capacitor
    And here is the L1 and L2
    Dec 2013
    5717
    The answer is in the first picture, the data tag on the motor. It's a 575V motor, you need a 230 or 230/460 motor. That motor will not work.
    Jim Dawson
    Sandy, Oregon, USA
    Apr 2018
    43
    I'm new to this... Thanks. Now I have to find a 10 HP 230/460 motor to run this 7.5 HP 575
    Dec 2013
    5717
    Would you explain what you are trying to do here, I'm now a bit confused. Do you need 575V, 3phase for the end use?
    Jim Dawson
    Sandy, Oregon, USA
    Mar 2017
    314
    that makes two of us.
    Sep 2006
    6463
    Hi.....No matter what you do it will not be a practical way to get 3 phase from single phase with a DIY rotary phase converter.
    You "can" balance the legs with no load on but as soon as the load is applied the voltages will go out of balance.........I spent 2 grand on a commercial rotary phase converter to run a Bridgeport mill because of that problem.
    If you run a 3 phase motor under load with unbalanced voltages long enough you risk burning out a winding.
    It is impossible to manually adjust the capacitor values for voltage balancing on the legs with a fluctuating load.....that's why commercial units have electronic circuitry to do the balancing on the go as the load varies.
    Ian.
    Dec 2013
    5717
    Quote Originally Posted by handlewanker View Post
    Ian.
    Ian, I'm going to disagree with you on this one. My DIY 15 hp RPC holds about 2 volts phase to phase under varying load. Unloaded my A-C leg is about 10 volts high (250V). As long as you are able to hold ~+/- 10% the motor will be fine at full load. With the normal fractional load, the voltage can vary even more without damaging the motor.
    Jim Dawson
    Sandy, Oregon, USA
    Apr 2018
    43
    I didn't know we can't use a 575v to build a rotary converter motor. Now I that I know that, I'll find a 10 hp 230/460 V and I'll use this 7.5 hp for my air compressor. Does it have to be 230/460? If it is just 460V on the nameplate is it ok?
    Dec 2013
    5717
    Quote Originally Posted by jfroux_1 View Post
    Not 460 only, but could be 230 only. If your input is 230 then you need 230 volt motor. When I say 230 volt that includes 220 to 240 volt.
    Do you have 575 volts available to run the air compressor with that 7.5 motor?
    Jim Dawson
    Sandy, Oregon, USA
    Apr 2018
    43
    No I don't. I thought the 10hp 230/460 volts would be able to feed the 7.5 hp 575 volts
    Dec 2013
    5717
    Sorry, without a transformer in the mix there is no way to get 575V out of 230V in. A rotary phase converter is Vout = roughly Vin. It converts single phase to 3 phase, but does not change the voltage too much. With proper balancing, Vout can = Vin +/- 2% or so phase to phase.
    Jim Dawson
    Sandy, Oregon, USA
    Apr 2018
    43
    Thanks for you input. I knew nothing about rotary convert few weeks ago. I thought it would be nice to run my air compressor and have 3 phases 575 volts in my garage. My main goal for now is to run my compressor (35 CFM). If I trade this 7.5 HP 575 volts for a 10 HP 230/460 will I be able to use this new 10 HP 3 phase motor with my 1 phase 220 volts in my garage to run my air compressor (for now I'll forget the idea of runing a rotary converter).
    Dec 2013
    5717
    To run at full capacity a 35 CFM compressor needs about 10 HP, and to run on single phase 230 V that's about 50 amps, do you have that much power available in your garage? A 3 phase motor will only develop about 2/3 of it's rated power running on single phase, and you still need a way to start it. You could use your rotary phase converter parts to build a Static Phase Converter to start the 10 HP motor. But at best it's going to develop about 6.5 HP running on single phase, and unless the unloader valve works well the motor may not start the compressor at all. Have you considered a Briggs & Stratton to run your compressor?
    Jim Dawson
    Sandy, Oregon, USA
    Apr 2018
    43
    Lol
    For now, I just have 30 amps. I hope one day I'll have 100 amps available in my garage. The option I can see now it to get a 15 HP 230/460 and use my parts to build a static phase and use a smaller pulley and pray that the unloader valve works.
    Dec 2013
    5717
    Why not just get a 5HP 230V single phase compressor duty motor, and run the pump at half speed. At least when it's running you'll have enough power left to run a couple of light bulbs.
    Jim Dawson
    Sandy, Oregon, USA
    Sep 2006
    6463
    A HUNDRED AMPS in a home workshop?????..........wow, that's almost like a death wish......we're talking about 24,000 watts if it's just 240 volts.....there must be some serious machining going on to need that capacity.
    Ian.
Page 1 of 4 123
  1. DM4400-what size 3 phase motor for rotary converter
    By drhanger in forum Dyna Mechtronics
    Last Post: 02-03-2017, 02:54 PM
  2. Motor hp for rotary converter panel
    By Cferrell84 in forum Phase Converters
    Last Post: 05-09-2016, 01:32 AM
  3. How to balance voltage on 3 phase?
    By bherr in forum Phase Converters
    Last Post: 12-26-2010, 10:26 PM
  4. Voltage Balance
    By lmarkie in forum Phase Converters
    Last Post: 05-16-2008, 04:10 PM
  5. Signal voltage converter?
    By gotis in forum CNC Machine Related Electronics
    Last Post: 10-28-2006, 12:32 PM
