586,096 active members*
3,397 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Centurion 6 Lathe Sample Program
Results 1 to 10 of 10
    Jul 2013
    5
    Hi all,
    I’m working on a post processor for a Milltronics lathe with Centurion 6.
    It would be very helpful if someone could post a sample g code program. The parts of the program I’m most interested in, are the beginning, the end, and the tool change sequence.
    Appreciate everyone’s help!
    Yogi
    Jul 2010
    548
    Re: Centurion 6 Lathe Sample Program
    Hi Yogi, If all else fails try doing a conversational program, then go look at in text. Program, edit, text it will be the Oxxxx ( O1234) that you made.
    sportybob
    Jul 2013
    5
    Thank you Bob! I’ll do that.
    I have a Fanuc post that looks to be very close, but needs some minor modification. Still, if someone has a short program to share, that would be very much appreciate.
    Yogi
    Jun 2010
    132
    Take a look at this YouTube video
    "https://www.youtube.com/watch?v=wXLakFO42cA"
    May 2005
    5
    duplicate
    May 2005
    5
    yogi107,
    Did you ever get the start, tool change and end codes? The conversational output is not easy to follow as a lot of it is not commented - so a pain...
    thanks
    pt
    Jul 2013
    5
    pt, yes, I put a post together that has been working satisfactory so far. The Centurion control accepts straight g-code, so I didn't have to mess with the conversational too much.
    Yogi
    May 2005
    5
    Quote Originally Posted by yogi107 View Post
    Yogi
    Yogi,
    I forgot to ask the obvious, what Cam system are you making the post for? I am looking for somebody with a Fusion 360 post for the Milltronics lathe. I can modify my own but I thought I ask as there are many hours of messing around if a noob like me is attempting this...
    Peter
    Jul 2013
    5
    Peter,
    I’m using Gibbs, with Posthaste as post processor.
    Yogi
    Mar 2005
    271
    Yogi
    Hi Yogi, would it be possible for you to post a small program for me so I can see what it looks like. I just got a Milltronics ML-15 with the Centurion 6 controller and I'm trying to figure out how to write a g code program.
    Thanks Mike
  1. Sample EIA program for Mazak lathe
    By extanker59 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-13-2013, 12:16 PM
  2. Sample program
    By BoKo in forum Colchester Tornado lathes
    Last Post: 10-11-2010, 08:49 AM
  3. Fanuc oi Mate-TC Lathe (Sample Program)
    By Tazzer in forum Fanuc
    Last Post: 03-17-2009, 06:10 AM
  4. need sample program
    By vintageracer in forum Milltronics
    Last Post: 11-15-2008, 10:58 PM
