586,123 active members*
3,378 visitors online*
    May 2007
    49
    Mori Seiki SL 7 - Zero Return not working
    Hi Friends ,
    I have Mori Seiki lathe SL 7 with Fanuc 6T - B control. Zero return for both axis is not working by selecting zero retun mode and moving the axis using jog switch. It does not catch zero point and hitting the limit. But, in MDI mode, using code, it is able to zero return in both axis. Can anybody help to solve this problem in zero return mode ? Thanks
    Mar 2017
    314
    Re: Mori Seiki SL 7 - Zero Return not working
    So it worked a few days ago and now it wont home? Or, you have never ran this machine before? Does it not move at all in zero return mode?
    May 2007
    49
    Quote Originally Posted by generaldisarray View Post
    Thanks for your reply. The machine had problems in spindle motor and drive. They were replaced. The machine was down for one year for some other problems also. Only few days before, I have taken over this machine. Previously, there was ER2 alarm on operating panel. I found it was due to reference return problem. Now, reference working in MDI mode. ER2 error is not there. The machine is working ok in auto mode. Still, the program downloading from laptop is not working. All the parameters are same as original values. Battery backup is ok. Though machine not working for one year, it was kept on everyday and tried some manual dry movements. Thanks.
    May 2007
    49
    I have found the mode selector switch is not working , when it is selected for zero return mode. Corresponding input bit 101.7 is not changing to 1 from 0 when checked in Diagnosis page. So, it could be either switch or wire problem. So, I hope , I can solve this problem now and this thread will be useful to some people who have similar problem. Thanks.
  1. Mori Seiki return to Microsoft Windows
    By MoriSeikiNoob in forum Mori Seiki Software
    Last Post: 02-04-2017, 12:26 AM
  2. Mori Seiki SL-1 - Zero Return on X Problem
    By NickHemingway in forum Mori Seiki lathes
    Last Post: 05-10-2016, 11:17 PM
  3. Replies: 0
    Last Post: 04-12-2016, 09:19 PM
  4. Mori Seiki zero return / home position
    By Her_cnc in forum Mori Seiki lathes
    Last Post: 11-14-2013, 01:09 AM
  5. Mori 11T zero return problem
    By wmpy in forum Fanuc
    Last Post: 10-15-2011, 08:15 PM
