Re: Power Mate- Model D Memory Card Problem(CRT MODEL)
I'll try this from memory, and hope it's the same control I'm thinking of.
After you put the memory card in the slot, push the program button.
That should bring up card on a soft key.
hit the soft key, and it will read the card and show you what is on it.
Other things will come up on the soft keys now.
Everything is numbered, so it asks you for the number, you can skip all the zeros and just type in 1,2.3........and then push the soft key for the number
Then type in the program number you want to use and push the soft key for the O number.
Then hit execute. That should work.
http://www.heavymetalcnc.com
