586,108 active members*
2,995 visitors online*
Thread: ball screw
    Mar 2018
    8
    ball screw
    I have had my cnc for years. it is 26 by 32 inches
    do the 2010 ballscrews seem about right?
    if so 2005 or 2010
    i want to build a larger format
    1500mm by 1500 mm
    I was thinking about 2010 for the 1500mm
    the basic square framework and gantry will be 80/20 3060
    with 1545 cross members
    it should be pretty rigid.
    use for cutting uhmw, other plastics, wood, some aluminum.
    servos
    are
    (3 Max)
    Part Number Frame Size
    (NEMA)
    Length
    (inches)
    Peak Torque
    (oz-in)
    Cont.(RMS) Trq
    (oz-in)
    Peak Power
    (W)
    Cont. Power
    (W)
    Rated Speed
    (RPM)
    Max Speed
    (RPM)
    PM-SDSK-3411 34 3.14 638 150.2 219.90 201.10 2010 2320
    Mar 2018
    8
    Re: ball screw
    really
    NO one knows if a 2005 or 2010 ball screw will whip at 60inchs on a rigid machnine 2500 max rpm?
    Re: ball screw
    For a router, you want at least 10mm pitch screws.
    If you really need 25m/min speeds, then get 2525 ballscrews, and gear the motor 2:1. I would not try spinning 2010 screws at 2500rpm.
    Apr 2010
    37
    Re: ball screw
    I'm only looking for 300 to 350 Rapids. Most my cutting is inches
    Sent from my SM-G955U using Tapatalk
  1. Ball nut arbor size for 1605 ball screw
    By kdoney in forum MetalWork Discussion
    Last Post: 04-08-2020, 07:45 AM
  2. Z axis to ball screw or not to ball screw
    By brian257 in forum Bridgeport / Hardinge Mills
    Last Post: 03-28-2012, 09:39 PM
  3. what bearing fit with acme screw 1/2 -10(for cheap ball screw)
    By apex in forum Linear and Rotary Motion
    Last Post: 07-27-2007, 05:15 PM
  4. New technology.... old debate.....ball screw vs lead screw
    By trubleshtr in forum Linear and Rotary Motion
    Last Post: 08-16-2005, 02:42 AM
  5. acme screw to ball screw question
    By Billw in forum DIY CNC Router Table Machines
    Last Post: 07-18-2005, 06:10 AM
