586,036 active members*
3,490 visitors online*
    Mar 2008
    375
    toughest steel
    maybe this is the right place to post this question
    I am trying to figure out what is one of the toughest or strongest steels out there with out heat treating it
    trying to make a punch and die to press some parts but the material has to be very strong . (steel)
    I was thinking of D2 steel.
    does any one have a good strong steel that they would recommend ?
    I am going to be pressing some SST .040 thick.
    any info would be greatly appreciated
    thank you
    Dec 2013
    5717
    Re: toughest steel
    D2 would be fine, but to be useful would need to be heat treated, it's pretty soft in the annealed condition. Is this going to be a punching or forming operation?
    Jim Dawson
    Sandy, Oregon, USA
    Mar 2008
    375
    Re: toughest steel
    It's going to be forming
    So basically what I was thinking is machine my punch to the size it needs to be then send it to get it anneal to (get harden )
    Then just polish up.
    I am just concern about dimension. Are the going to get bigger or smaller
    Also is there a way I can harden it myself or does a special shop need to do this
    Thank you for the replie
    Dec 2013
    5717
    Re: toughest steel
    A6 might be a better choice for forming dies, much more forgiving to machine than D2. Harden and draw back to about a R56-58C, unless you are coining the material then D2 or S7 would be the better choice. In that case, you would want to harden to about R60-62C. To harden and draw correctly takes special heat treat ovens, possible to do in the home shop but best results would be obtained from a heat treat shop if you don't have experience at doing it.
    D2 tends to grow very slightly when heat treated, maybe 0.0005/inch of thickness. A2 and A6 is normally very stable in heat treat. Of the tool steels I mentioned above, D2 is the most abrasion resistant due to it high chrome content.
    Jim Dawson
    Sandy, Oregon, USA
    Mar 2008
    375
    Re: toughest steel
    Thank you
    I think I will be trying the d2 and like you said harden to R60-62c
    Thank you
  1. Replies: 4
    Last Post: 07-05-2017, 06:05 AM
  2. 2014 NASCC : The Steel Conference & World Steel Bridge Symposium
    By Ajancnc in forum Trade Shows / Webinars / Other Events
    Last Post: 03-06-2014, 10:58 AM
  3. Replies: 2
    Last Post: 11-19-2013, 09:03 PM
  4. hsm on steel
    By seawolf217 in forum MetalWork Discussion
    Last Post: 06-07-2009, 01:17 AM
