586,077 active members*
3,670 visitors online*
    Apr 2018
    DIY CNC Mach3 aligned squares
    Hello everybody i apologize for my english, i try to explain my problem with CNC.
    I have new DIY CNC and i try to calibrate mach3, for cam i use mastercam, but when i cut two big square, in front side the measures its ok, but when i put one in front and the other in back side, this parts its no aligned
    I upload some pictures, maybe its problem of step per mm? i use axis calibration assist of mach3 and linear precision scale, check slack before and all its ok.
    My cnc have two motors on X Axis
    Many thanks!
    Nov 2008
    110
    Re: DIY CNC Mach3 aligned squares
    I guess x axis is not perpendicular to y axis. Probably you need to adjust x axis motors independently till all corners are square
  1. All my dimensions show as black squares?
    By zane in forum Solidworks
    Last Post: 07-14-2011, 07:33 PM
  2. Squares are square, circles are not round
    By brtech in forum WoodWorking Topics
    Last Post: 01-18-2011, 03:30 PM
  3. Looking for a machine to cut Squares only-Dont want to pay too much
    By elitbox in forum Want To Buy...Need help!
    Last Post: 11-26-2010, 05:20 AM
  4. HOLES LOOK LIKE SQUARES
    By Pure-Powder in forum Waterjet General Topics
    Last Post: 05-05-2008, 04:56 PM
  5. Laser squares and levels
    By atifeh in forum Mechanical Calculations/Engineering Design
    Last Post: 10-19-2005, 09:47 AM
