586,036 active members*
3,571 visitors online*
IndustryArena Forum > CAM Software > Mastercam > 3D toolpath rolls the edges
    Jan 2012
    55
    Hi All,
    I'm having a problem creating a toolpath that doesn't roll the edges when entering and exiting. I have a 3D surface and have tried just about every finishing toolpath and cannot get the tool to enter/exit without rolling the edge over. I'm sure my lack of experience is the problem and I'm not setting something correctly. Any advice would be greatly appreciated.
    ~Dale
    Dec 2008
    3109
    Re: 3D toolpath rolls the edges
    Check your operation parameters for that toolpath, particularly the "Advanced Settings" ( should be "Automatically" or "Only between Surfaces" )
    - "All over" will make the tool roll over the edges
    "Gap settings" control transitions between steps and surface edges, be careful on the use of the tangential lead in/out & tangent line length as these are typical gouge zones
    "Tool Containment" can also be used to restrict the path relative to the surface boundary ( "Centre" allows the tool to cover a flat surface to the boundary, but if it is sloped then the path won't finish the entire surface)
    Jan 2012
    55
    Now for my next inexperienced question, I am trying to program my part using raster 3D toolpath in Mastercam 2018 and I looked in the parameters area for the advanced settings and can't seem to locate them am I looking in the wrong spot?
    ~Dale
  1. 4 rolls
    By julio_gyn in forum Bending, Forging, Extrusion...
    Last Post: 02-27-2013, 10:23 PM
  2. Plate Bending Rolls
    By rtegantvoort in forum Uncategorised MetalWorking Machines
    Last Post: 02-22-2013, 11:24 PM
  3. 10"OD x 4' Rubber rolls on a lathe
    By srill in forum Material Machining Solutions
    Last Post: 01-06-2010, 01:03 AM
  4. Grinding Rubber printing rolls
    By quadbob in forum MetalWork Discussion
    Last Post: 02-23-2009, 07:38 PM
