586,358 active members*
3,530 visitors online*
IndustryArena Forum > CNC Electronics > Dmm Technology > Brand new DYN4 400W set - goes in Overcurrent fault as soon as motor is connected
Page 2 of 2 12
Results 21 to 23 of 23
  1. #21
    Nov 2015
    5
    Re: Brand new DYN4 400W set - goes in Overcurrent fault as soon as motor is connected
    Hello,
    I'm trying to wire up 2 of the same DYN4 400w 200v (lathe setup). Most people are telling me just to wire it up for 120vac. I've got access to 220vac just as easily.
    So, I have 2 questions:
    1. Which voltage do you guys recommend (and why)?
    2. Which magnetic contactor should I use for 120vac or 220vac?
    From what I read I need my model requires 1 - 10a 120vac (DIN mount in my case) magnetic contactor per controller. Can anyone recommend a part # for me?
    Also, apparently the noise filters are "optional" when going with 120v but I already purchased a couple along with a line reactor. I prefer to go with "better to be safe, than sorry".
    I have no idea why I'm having such a hard time with this - ugh!
    I greatly appreciate any info/advice.
    Cheers!
    -Sam
  2. #22
    Dec 2013
    5717
    If you are asking only about the contactor, there are 3 parameters to concider. Switching voltage, switching current, and coil voltage. Most contactors are rated at a minimum of 250V, switching current is stated as is the coil voltage. The switching voltage and current need to be compatible with the drive, the coil voltage needs to be compatible with your control voltage.
    An example of contactors that would work.
    https://www.automationdirect.com/adc..._-z-_overloads
    Don't forget to add the proper circuit breakers ahead of the contactor(s) per the DMM installation instructions.
    Jim Dawson
    Sandy, Oregon, USA
  3. #23
    15362
    Quote Originally Posted by samtheclip View Post
    Hello,
    Cheers!
    -Sam
    You need the power filters no matter what voltage you use
    You only need ( 1 ) contactor as long as it can handle the current for the ( 2 ) drives
    Either voltage will work 240v is always going to be better if you have it
    Mactec54
Page 2 of 2 12
  1. DYN4 1.8KW Servo Motor
    By Vinnito1 in forum Dmm Technology
    Last Post: 03-25-2019, 03:11 AM
  2. DMM Dyn4 & 1KW AC Servo motor reliability & quality
    By Marty_Escarcega in forum Dmm Technology
    Last Post: 06-27-2017, 03:01 PM
  3. Eathtek 400W spindle motor
    By ProtoXNH in forum DIY CNC Router Table Machines
    Last Post: 12-04-2016, 02:52 PM
  4. AC motor connected to Raspberry Pi
    By schitale in forum Servo Motors / Drives
    Last Post: 01-02-2014, 07:55 AM
  5. What free servo controller used for brush DC motor 400W ?
    By Qwerfk in forum Open Source Controller Boards
    Last Post: 01-10-2013, 05:18 PM
