586,036 active members*
3,521 visitors online*
    Mar 2018
    Cnc plasma ( water cooled or air cooled )
    I've chinese plasma cutting machine. I'm new to plasma cutting. I've a question how to decide that i should use air cooled tip or water cooled plasma tip ?
    I should use water filled up in my table 'pictures attached ' or my table should be dry ?
    I tried to cut 3mm mild steel at 45 amps and 3000mm per minute and it damaged my table grill .
    I'm really confused.
    Attachment 390582Attachment 390584Attachment 390586Attachment 390588
    Oct 2004
    178
    Re: Cnc plasma ( water cooled or air cooled )
    My plasma torches were always air cooled. Water cooled sounds like a good idea, maybe complicated tho. The grill under the sheet is expendable, expect to replace the slats occasionally.
    Mar 2018
    Quote Originally Posted by greggv View Post
    Why this blue pipe is here ?
    Mar 2018
    While cutting 8mm mild steelsheet with plasma, cut is at angle of 45 degree from 2 sides while other 2 sides are at 90 degree. How i should make 45 degree to 90. Current is 100 amps and speed is 500mm/min.
    Sent from my SM-J710FN using Tapatalk
  1. Crazy Idea - converting Air Cooled spindle to Water Cooled
    By BanduraMaker in forum DIY CNC Router Table Machines
    Last Post: 01-20-2018, 02:29 AM
  2. Air Cooled vs Water Cooled Pros and Cons and Advice
    By Tundraman in forum Spindles / VFD
    Last Post: 06-20-2015, 08:41 PM
  3. Replies: 0
    Last Post: 04-27-2014, 03:49 AM
  4. water cooled spindle vs air cooled
    By ken2010 in forum Chinese Machines
    Last Post: 10-21-2013, 06:03 PM
  5. Air cooled or water cooled ?
    By anstac in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-23-2009, 09:12 AM
