586,036 active members*
3,506 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > Upgrading my 3040 with a 500W spindle (replacing the 300W one)
Results 1 to 6 of 6
    Jan 2018
    14
    Hello,
    i have bought a 3040 cnc machine from a seller on ebay. This machine has a 300w spindle and is working fine. I have also a 500W spindle that is probably laying around since 1 year in my home. An 500W powersupply and a soldered VFD came with it.
    Now, i would like to use this 500 W spindle with this machine, but would like to keep the PWM feature that the 300W spindle has. In other words mach 3 can turn the spindle on/off and i can adjust directly the rpm in the software.
    My break out board in the controller box is the NT65-3X. Does anybody know how i have to connect this all? I dont know anything about electronics and this is why i ask here for help
    I have made pictures of the controller box and the spindle etc.
    I thank you for all the answers in advance
    Apr 2009
    Re: Upgrading my 3040 with a 500W spindle (replacing the 300W one)
    Hello
    Did you find any answer?
    I have the same issue like yours
    Mar 2007
    2083
    as the new speed control has connections for 10V analogue control and a potentiometer
    I expect you can add a PWM to analogue converter to convert the PWM signal from the stepper board
Name:	PWM CONVERTER PLUS SPINDLE SPEED CONTROLE.jpg
    John
    Apr 2009
    Thank you so much for your answer john
    Appreciate
    Mar 2007
    2083
    in addition to posts like this on cnczone
    https://www.cnczone.com/forums/chine...oc-pw3024.html
    I found this circuit of the stepper driver board and PSU & spindle control online
    (CNC, Hacks, Projects...: CNC Engraver Schematics (YOOCNC-NT65-3X) )
    PDF stepper driver
    stepper controller.pdf
    low res stepper driver jpeg
    spindle control & PSU PDF
    I have highlighted the PWM path on the stepper driver board needed to be connected to the PWM to analogue converter
    Attachment 410852
    PWM connector J5 that is normally connected to P4 on the PSU & spindle control board
    J5 is what needs to be connected to a PWM to analogue converter
    John
    PS
    Attachment 410866
    Nov 2008
    11
    I can't help with the upgrade request, but would REALLY like to know how you got yours responding to the PWM control.
    I have the exact same controller setup as the OP, but I can't get mine to work.
  1. 3040 with all ball screws and 300W spindle, no electronics
    By james_III in forum Chinese Machines
    Last Post: 08-07-2016, 07:10 PM
  2. China metal fiber laser cutting machine 300W/500W/750W/1000W
    By Wendydekcel in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-14-2016, 11:39 AM
  3. 300W Air Cooled Spindle + PWM
    By kolias in forum Open Source CNC Machine Designs
    Last Post: 10-22-2013, 11:15 PM
