586,070 active members*
3,543 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc NCGuide connection issue with Ladder III
    Apr 2018
    I have been using NCGuide with Ladder III on my PC for a over a year now. After a short break from Fanuc work, I came back to Fanuc projects and my Ladder III will not connect to NCGuide using the loopback 127.0.0.1. A few days later it worked for a couple days. Now it's not working and I haven't been able to get it back. Any ideas on where to start? A fresh install is not an option at this point unfortunately. Keep in mind I only use this PC for my Fanuc projects, so there has been no new installs or network configurations. And there definately has not been any changes between it working then not working then working again.
    Mar 2013
    27
    Re: Fanuc NCGuide connection issue with Ladder III
    Quote Originally Posted by cnc_jmartin View Post
    To use the internal bridge, you have to be connected to a real network. Maybe this was the issue?
    Verzonden vanaf mijn iPhone met Tapatalk
    Apr 2018
    After trying several thing, the only method that works repeatedly is to make sure I have NCGuide closed. Then disable my ethernet NIC, wifi card doesn't matter. Then load NCGuide and enable my ethernet NIC card. I can't explain why, but it consistently fails if I don't and it consistently works when I do.
  1. Replies: 7
    Last Post: 04-11-2018, 03:57 AM
  2. Fanuc Ladder III Ethernet connection
    By minDark in forum Fanuc
    Last Post: 06-29-2014, 01:02 PM
  3. 840D ladder uploading issue
    By guhl in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 10-22-2013, 05:29 PM
  4. Fanuc Ladder III software issue
    By Walz in forum Fanuc
    Last Post: 05-09-2012, 12:45 PM
  5. FANUC NCGUIDE Pro
    By ker2008 in forum Fanuc
    Last Post: 06-10-2011, 09:34 PM
