586,655 active members*
2,612 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > StepperOnline.com NEMA 23 "kit" issues
Results 1 to 14 of 14
    Dec 2017
    7
    New kid on the block here. I put together a modest sized 3-axis (4 motor) CNC, and purchased StepperOnline's 4-Axis 269 oz-in (1.4 ft-lb) NEMA 23 kit to power it with.
    The problem I am having is that I can't get anything that remotely resembles stability except at extremely low speeds (< 30 IPM) and with single-stepping, and even then the system seems to 'lose' a few pulses.
    Each axis runs well solo - quiet, smooth, and w/ no apparent loss of position (unless I jack up any of the parameters - speed, micro-stepping, etc.) but, when all run together there is LOTS of harmonic-sounding noise and even occasional stalling.
    Particulars:
    Bed size 38 x 48
    Gantry & Carriages "rails" are V-Groove bearings - very low rolling resistance (not measured - yet)
    Complete gantry assembly weight is probably around 35 lbs
    Cross - machine carriage weight = ~ 4 lbs
    Vertical carriage w/ router = ~ 5 lbs
    Drives are all 10 pitch x 1/2" ACME screws w/ Delrin anti-backlash nuts.
    Torque requirements (again not yet measured) seem quite low - I can very easily turn the screws by hand.
    Alignment is all very good.
    Wiring
    All grounded (120VAC, 24VDC, machine)
    non-shielded 18 AWG 2 conductor cable used for all motors (each pair feeds one motor winding)
    NO interlock wiring has been done yet (limits, e-stop, etc.)
    Software / setup
    Using Mach3, all config'd as per the driver manufacturers recommendations.
    Might I simply be asking too much from NEMA 23's ? They seem to have plenty of torque (gantry movement has damaged a few things rather than stalling)
    Is this to be expected from an extremely cheap system ?
    I've contacted the seller of the kit - they're not much use (surprise)
    I have had plenty of experience years ago with industrial stepper motor systems and never encountered any of the issues I'm having here.
    Any and all suggestions / questions are welcome.
    Thanks to all in advance
    Wayne
    Re: StepperOnline.com NEMA 23 "kit" issues
    Link to the kit?
    Have you run drivertest.exe in the Mach3 folder?
    If they are cheap drives, you may be getting resonance issues. You should have them set to 1/8 or 1/10 microstepping, but even then you may still be running into resonance issues. I have dampers on my steppers, to get rid of the resonance.
    At 24V, you won't see much speed out of that system with 1/2-10 acme. Best case is probably 50-60ipm?
    Dec 2017
    7
    Link to the kit? https://www.omc-stepperonline.com/cn...60-23hs30.html
    Have you run drivertest.exe in the Mach3 folder? ​​Yes. That passes with flying colors.
    If they are cheap drives, you may be getting resonance issues. ​​ They're cheap. Extremely so.
    You should have them set to 1/8 or 1/10 microstepping, but even then you may still be running into resonance issues. ​​ I can't even st them to 1/2 or 1/4 without all kinds of issues
    I have dampers on my steppers, to get rid of the resonance. â€â€‹ I will have to look into this - any examples you might be able t point me to ?
    ​​ Yes. 600 RPM would be 60 IPM - likely max. Went with the 10 TPI screws to maximize mechanical advantage. Figured screws & nuts are relatively cheap - I could jump to higher pitch (lower TPI) if this worked out................
    Thanks for responding !
    Wayne
    Have you run drivertest.exe in the Mach3 folder? Yes. That passes with flying colors.
    Are you relying on the "System Excellent" message? If so, that is meaningless. Make sure you have a perfectly flat line, with a pulse rate that stays steady, and is very close to the kernel speed. At 25Khz, the pulse rate should be right around 25,000, and not fluctuate much at all.
    This thread is where I got the idea for the dampers, and I think I have a pic in there somewhere.
    https://www.cnczone.com/forums/stepp...er-damper.html
    What are the issues? Do you change the steps/unit in Mach3 when you change the microstepping, as well as the accel and velocity?
    Dec 2017
    7
    Nope - didn't even notice the "System Excellent" bit right off
    Line is generally perfectly flat with occasional low-magnitude 'spikes' (far less magnitude than shown in the tutorial video) although with more frequency when it does happen.
    Pulse rate is generally at 24995/6 but occasionally drops to 24260-ish
    Yes, steps / unit changed when microstepping changes made. Accel, no (been set to 3 ips/s for all) Velocity, no - I haven't tried going below 15 ipm. Above 20 causes real problems regardless of microstep settings
    Thanks, again
    May 2015
    686
    They seem to be the same drives as I use. But I'm running them at 48 volts with different drivers (Longs Motor DM542A). I've been happy with them. I microstep them at 20 x and can get 750 RPM out of them. I'm not using Mach or a parallel port but am using Linuxcnc and a Mesa 7i76e ethernet card that can step at up to 10 Mhz. I would be looking at your driver and voltage. I got a feeling your choice of driver is pretty appalling.....
    Rod Webster
    www.vehiclemods.net.au
    After changing the microstep settings, you need to restart, and redo the accel and velocity settings. I thought there was a pop up message that told you this?
    What exactly does this mean? Do they just run rough? Stall? Have you tried jogging at different speeds, like 10, and 50? Try increasing the accel to 5, or 10, and see if it makes a difference. If it's a resonance issues, different accel rates can help get through resonance points.
    Dec 2017
    7
    Do they just run rough? Stall? All of the above - noisy, stuttering, stalling
    Have tried Jogging at various speeds - haven't tried above 30 bc at 25 and 30 things go 'bad'. Figured faster wouldn't improve things.
    Individual Axis' also behave better alone than when running together running code. For example, just jogging any one of the three axis at speeds up to 20 IPM they run very smooth and quiet as opposed to when even just the X&Y are making a coordinated move. Even something as simple as returning to 0,0 X-Y which should be straight-forward, single direction, single speed moves from wherever it may have been at produces a lot of 'harmonic-ey' noise at any speed (including 20 IPM) and tends to result in hesitation and / or stalling above 20 IPM.
    I'm fabbing up a set of dampers to see if they provide any benefit...................
    If one axis moves smooth by itself, but multiple axis together don't, I would think it's a PC issue. Open your Windows task manager and check CPU usage while it's moving.
    May 2015
    686
    Or migrate to LinuxCNC
    Rod Webster
    Dec 2017
    7
    Well, not getting much of anywhere with this one. checked CPU/Memory useage while running GCode and CPU useage peaks around 19%, mostly runs around 10%. Memory is only using about 300Mb of the 800 installed.
    Built a pair of 3" / 8 ball dampers and installed them on my X & slaved A axis' - no effect at all. As soon as I bump the speed up to 30 IPM from a relatively stable 20 IPM I get stalls as before. Changing accel rates doesn't seem to affect it either
    I don't think the motors themselves are inadequate for the job - it takes a lot of force to stop the gantry movement by hand when jogging. I suspect that the el-cheapo drivers may well be a case of "you get what you pay for".
    Dec 2017
    Hi there,
    I've had the exact same problem. Problem was that my 5Volts supply to the Stepperonline mach3 breakoutboard was not connected. In that case the signals are to weak (together). Connected the 5V power supply to the board and all problems were gone....
    Mar 2024
    4
    I also have similar problem, but now have solved. My stepper motor buy from https://www.oyostepper.it/category-6...o-NEMA-17.html and my power supply from:https://www.skysmotor.co.uk/category...er-Supply.html , their customer help me solve the problem.
    Dec 2012
    203
    check the power supply wiring, I would use 16 or even better 14 AWG between power supply and drivers and connect a capacitor 100nF and a elco 100uF close to each driver.
    If the cables to the motors are long, I would also use 16 AWG for these and advise shielded. These steps will help in preventing interference between the axis. It will not solve the max speed you can reach. That's related to the motor inductance and the driver voltage. A lower inductance and / or a higher driver voltage will give a higher speed.
  1. How can do ""manual stepper motor sizing for "rack and pinion"calculation""???
    By Medhat93 in forum Mechanical Calculations/Engineering Design
    Last Post: 03-03-2018, 01:50 AM
  2. Replies: 7
    Last Post: 01-10-2015, 01:40 PM
  3. Replies: 5
    Last Post: 01-12-2014, 07:07 PM
  4. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  5. Gecko G540 for 20" x 30" x 5" / Nema 23 XYZ CNC?
    By telmnstr in forum DIY CNC Router Table Machines
    Last Post: 06-09-2012, 11:50 AM
