586,032 active members*
3,056 visitors online*
Results 1 to 17 of 17
    Oct 2008
    39
    3D probing to create point cloud.
    Hello,
    I have very little experience with C programming.
    I’m am looking for a C program to probe a 3D surface and create the output file in a comma-delimited file or another format to create a point cloud. File will be used to create a 3D machining program.
    I’m only using Kflop, Kanalog, Konnect, &KMotionCNC to run my machine which is a custom retrofit from a Yamaha X Y Z robot.
    Also, I have a G-Code program that I found online. It uses G38.3 and macro variables. is there a plan to add G38.x Straight probe to the EMC.var file?
    May 2006
    4045
    Re: 3D probing to create point cloud.
    Hi eng101,
    Can you describe in detail how and what strategy you would wish to use to do the probing?
    Do you have your probe interfaced to KFLOP?
    We don't have plans to add G38.x but you should be able to do the equivalent with custom MCodes.
    See this Thread (you might ask if JoeKumanchik is willing to share his code):
    https://www.cnczone.com/forums/dynom...ml#post1999582
    Here is a basic ProbeDirection.c example:
    Code:
    #include "KMotionDef.h"
    // For basic KMotionCNC Probing configure KMotionCNC to call this C Program
    // with an MCode and 3 parameters P Q R passed in variables 50,51,52 to
    // specify the X Y Z Probe directions speeds
    // Modify this program for the input bit you are using for your probe.  As
    // written the program keeps moving until the bit goes high.  If the polarity
    // of your probe is opposit this then remove the NOT Symbol '!' applied to the
    // ReadBit result.
    // For Example:
    // M100 = Exec/Wait/Sync  Thread 2 Var 50 <>\C programs\ProbeDirection.c
    // Then to probe in the X direction at 100 counts/sec use GCode as:
    // M100 P100 Q0 R0
    // Then to probe in the Y direction at 50 counts/sec use GCode as:
    // M100 P0 Q50 R0
    main()
    	Jog(0,*(float *)&persist.UserData[50]);	// move in the velocites specified
    	Jog(1,*(float *)&persist.UserData[51]);
    	Jog(2,*(float *)&persist.UserData[52]);
    //	printf("X Y Z Speeds = %f %f %f\n",
    //		*(float *)&persist.UserData[50],
    //		*(float *)&persist.UserData[51],
    //		*(float *)&persist.UserData[52]);
    	while (!ReadBit(46)) ;   		// wait for switch to go high
    	Jog(0,0); 						//Stop
    	Jog(1,0);
    	Jog(2,0);
    Doing all the probing in KFLOP in C rather than in the PC in GCode would probably be somewhat faster if that is an issue.
    Here is a code fragment writing CSV data to a disk file taken from the CaptureXYZMotionToFile.c example.
    Code:
    	p=gather_buffer;
    	FILE *f=fopen("C:\\temp\\kflopdata.txt","wt");
    	for (i=0; i<N; i++)
    		// round times to neaarest servo tick
    		p[0] = ((int)(p[0]/TIMEBASE + 0.5))*TIMEBASE;
    		fprintf(f,"%16.9f,%16.3f,%16.3f,%16.3f\n",p[0],p[1],p[2],p[3]);
    		p += 4;
    	fclose(f);
    Regards
    TK
    http://dynomotion.com
    Oct 2008
    39
    My strategy would be a XY grid and probe in Z. I'm currently using my tool setter as a probe for testing.
    I have read your post to JoeKumanchik and I have contacted him.
    I am learning, I have a little understanding about using three M codes, Open file, Probe and loop, then close file.
    I have a program that uses Subroutines in the form of O1 and Looping: do, while, endwhile as well as Conditional: if, else, endif.
    When I try to run it KmotionCNC gives me G code error; Unknown word starting with F. example o3 if [#1202 lt #1201]
    Does KmotionCNC support the execution of Logical expressions
    Thank you,
    May 2006
    4045
    Hi eng101,
    KMotionCNC can do subroutine loops and conditionals, but not with 'if' and 'while' statements.
    You would need to re-write the program in a form of something like a subroutine to do a row and a subroutine to do a grid point. Then loop the subroutines the appropriate number of times.
    Here are some examples (from the SubroutineWithConditionals.ngc example):
    Code:
    G20
    #100 = 5
    (examples of logical operations)
    (result is 1 if condition is true)
    (result is 0 if condition is false)
    #101 = [#100 >  5]
    #102 = [#100 >= 5]
    #103 = [#100 <  5]
    #104 = [#100 <= 5]
    #105 = [#100 =  5]
    #106 = [#100 <> 5]
    (subroutine call can be looped a number of times)
    (the L or Q word may be used to specify the count)
    (if neither L or Q is specified a count of 1 is used)
    (if the count is 0 the subroutine will not be called at all)
    M98 P1 L3  (example using L to specify the loop count)
    M98 P1 Q3  (example using Q to specify the loop count)
    M98 P1 L#100  (example using a variable loop count)
    M98 P1 L[5 > 4]  (example using a conditional as a loop count)
    M2
    O1
    #200 = [#200+1]
    M99
    HTH
    Regards
    TK
    Oct 2008
    39
    Hello Tom,
    This is my current Version of software.
    KFLOP 4.33 Build 18:05:42 Dec 1 2015
    I tried running the SubroutineWithConditionals the programs runs but when I tried to modify a statement
    [#100 > 5] GOTO 10 ( GCode Error: Unknown word where unary operation could be
    M98 P1
    N10
    Is this error do to the software Version?
    Also I am running on a laptop with Windows XP Professional service Pack 3.
    Please recommend latest version of software to run.
    Thank you,
    May 2006
    4045
    Hi eng101,
    GOTO is not supported. Instead there is M98 which is a subroutine call. The P parameter indicates which subroutine to jump to (with a matching O word). The L parameter (loop count) can be used as the number of times to call the subroutine. A conditional expression for the L parameter when evaluated to be 1 (true) or 0 (false) can be used to call a subroutine one time or zero times (not at all).
    The latest Releases can be found here, but none support IF, WHILE, or GOTO:
    Dynomotion
    Regards
    TK
    Oct 2008
    39
    Quote Originally Posted by TomKerekes View Post
    Hi eng101,
    Dynomotion
    Regards
    Hello Tom,
    I have been able to work out a solution for probing, but saving the data to a file has become my next hurdle.
    The following code sends the starting point of X,Y,Z the file FILE *f=fopen("C:\\temp\\kflopdata.txt","wt"); just fine.
    Xneg = ch0->Dest; // stores the current position as the start of the data gather line
    Yneg = ch1->Dest;
    Zpos = ch2->Dest;
    //fprintf(f,"%8.3f,%8.3f,%8.3f\n",(ch0->Dest),(ch1->Dest),(ch2->Dest)); // Test print to file 5/8/2018 OK
    //fprintf(f,"\n");
    //fprintf(f,"%8.3f,%8.3f,%8.3f\n",(ch0->Dest+1),(ch1->Dest+2),(ch2->Dest+3));
    //fclose(f);
    Ignor the //, It correctly saved to the file.
    0.00, 0.00, 0,00
    blank line I added these next two lines just to make sure.
    1.00, 2.00, 3.00.
    But when inside of a nested For loop.
    if (!ReadBit(1055)) // only save the position if the probe was triggered
    fprintf(f,"%16.3f,%16.3f,%16.3f\n",(ch0->Dest/StepsPerMM),(ch1->Dest/StepsPerMM),(ch2->Dest/ZaxisIndex_mm)); // write the three axis coordinates to file with commas (ch0->Dest/StepsPerMM),(ch1->Dest/StepsPerMM),(ch2->Dest/ZaxisIndex_mm))
    The file is opened, the date and time the file is modified is updated but no data is present.
    Any thoughts, would be helpful.
    Has anyone else in the Zone had this problem and would you share your solution?.
    Thank you
    May 2006
    4045
    Hi eng101,
    I can't see any obvious issue. It only saves data to the file when bit1055 is not set. '!' is the 'not' operator. Was that your intention? Maybe you could show us your whole program.
    Regards
    TK
    Oct 2008
    39
    Hello Tom,
    Yes, My tool setter is always logic Hi or 1 until it is depressed.
    Quick note I removed the brackets for the print command in the nested loop, now it prints to the file.
    One problem, the value for Z is always zero.
    In this example:
    for(y=0; y<Yloop+1; y++) // 2nd for Loop (for Loop int. Condition; Increment) however many Yloops make the increment and start probe at new Y position, Checked and corrected Loop OK 5/6/2018
    { // Start of Code Block
    MoveAtVel(2,-ZMAX,1800); // y<Yloop=True. Move the z axis to the lower position at a low speed
    //5/4/2018 float ZMAX = *(float *)&persist.UserData[52]*ZaxisIndex_mm; checked OK
    while(!CheckDone(2) && !ReadBit(1055)); // check for either probe contact or the end of the move
    Jog(2,0.0); // stops the movement on the Z axis
    P0 = ch0->Dest; // stores the current position as the start of the data gather line
    P1 = ch1->Dest;
    //{ Removed Brackets 5/10/2018 now prints to file
    P2 = ch2->Dest;
    fprintf(f,"%8.3f,%8.3f,%8.3f\n",(P0/StepsPerMM),(P1/StepsPerMM),(P2/ZaxisIndex_mm)); // write the three axis coordinates to file with commas (ch0->Dest/StepsPerMM),(ch1->Dest/StepsPerMM),(ch2->Dest/ZaxisIndex_mm))
    //} Removed parentheses 5/10/2018
    Delay_sec(.2); // Delay .2 seconds
    Move(2,Zpos); // raise the Z axis to the upper position
    while (!CheckDone(2)); // Check if motion is complete
    Output :
    0.00 0.00 0.00
    0.00 0.50 0.00
    0.00 1.00 0.00
    0.50 0.00 0.00
    0.50 0.50 0.00
    0.50 1.00 0.00
    ect.
    But in this example:
    Yneg = ch1->Dest;
    if (!ReadBit(1055)) This test completed 5/10/2018 for print file OK
    Zpos = ch2->Dest;
    fprintf(f,"\n");
    fclose(f);
    Output is:
    0.00 0.00 -3.612
    Any thoughts
    Thank you for support
    May 2006
    4045
    Hi eng101,
    I tried to explain in my last email. The problem is with the '!' operator. Because your probe goes high when it is triggered the bit will normally be high. The code will only print the data when the bit is not high (low), So the "if" statement skips reading Z and printing. By removing the brackets then only one line is skipped (reading Z) so Z prints garbage. Keep the brackets and try removing the '!' operator to be like this:
    Code:
    if (ReadBit(1055)) // only save the position if the probe was triggered
        P2 = ch2->Dest;
    Regards
    TK
    Oct 2008
    39
    Thanks tom,
    I miss understood, I thought I was inverting the input for some reason.
    It is now working.
    Now the the next issue, I've created a point could, now what do I do with it.
    This is not a issue with Dynomotion but there has been others working on this. What have you all out there used to convert your data into something useful.
    I have Inventor 2010 Pro, importing points at the moment has not worked.
    Mastercam 8.1 for mill
    Autocad 2011
    Is there a good freeware package out there?
    Thank in advance.
    May 2006
    4045
    Hi eng101,
    Glad to hear you got it working. Would you mind posting your final code? It would be fun to see a scan.
    It would probably help for you to explain what you are trying to accomplish.
    A Google search found Meshlab which is an Open Source program that seems to be able to convert point cloud to stl format and others.
    MeshLab
    https://youtu.be/ymVgDTxAQlU
    Regards
    TK
    Jun 2004
    355
    I've imported point clouds to Solidworks and Fusion360 in the past, however they were in DXF format.
    I've not done any for a while and certainly not since I've moved to F360, but my workflow used to be export/import the point cloud DXF from Mach3/Probe-It wizard into Solidworks to tidy up the cloud and create a drawing/model, then export/import a STL/Step to CamBam.
    But without the initial DXF file, I think Tom's suggestion of MeshLab is probably worth a shot first.
    Oct 2008
    39
    Here is what I have so far.
    Attachment 394292Attachment 394292Attachment 394294
    This is a test scan of a section of a motorcycle gas tank.
    After scanning the txt file is opened in Excel for conversion the the points are imported into inventor.
    One picture shows the lines created by the points the other is after lofting a surface.
    This the C program so far:
    // New Probe Direction Rev. 1
    // Completed 5/13/2018
    // specify the Xmax Ymax Z depth.
    // of your probe is opposite of this then remove the NOT Symbol '!' applied to the
    // ReadBit result.
    // For Example:
    // M100 P2 Q2 R2
    // M100 = Exec/Wat/Sync Thread 2 Var 50 <>\C programs\NewProbeDirection.c
    // Move to X and Y starting point currenly hard coded within probing program.
    // Then to probe in the y (Q) direction at .5mm steps
    // Z moves toward Zmax depth, if probe is trigger then the three points are save to file
    // Z returns to starting position and Y increments .5mm
    // at the end of the Y for loop Y returns to start point and X icrements .5mm
    // This is repeated untill X and Y both reach max.
    // PlANED UPDATES:
    // Move to fixture Offset for starting point.
    // Modify R parmameter to be uesd for changing probing resolution.
    // Develop smoother probe pattern with use of Uni-direction(6 Ball) Probe.
    #define TMP 10 // which spare persist to use to transfer data
    #include "KflopToKMotionCNCFunctions.c"
    #define Zaxis 2
    #define Xaxis 0
    #define Yaxis 1
    #define StepsPerMM 410 // CNTS to move X or Y axis 1.0mm
    #define XaxisIndex_mm 205 // CNTS to move Xaxis 0.5mm
    #define YaxisIndex_mm 205 // CNTS to move Yaxis 0.5mm
    #define ToolProbePin 1055
    #define ToolProbeX 10413 // X START POSITION OF PROBE
    #define ToolProbeY 10000 // Y START POSITION OF PROBE 20500
    #define PlusZaxisIndex_mm 820.00 // CNTS to move Probe 0.5mm up
    #define MinusZaxisIndex_mm 328.00 // CNTS to move Probe 0.2mm Down
    #define ZaxisIndex_mm 1640 // CNTS to move Zaxis 1.0mm
    #define Xmax persist.UserData[50] //Set to X max BY M100 Q FOR X AXIS
    #define Ymax persist.UserData[51] //Set to Y max BY M100 P FOR Y AXIS
    #define Zmax persist.UserData[52] //Set to Z max BY M100 R FOR Z AXIS
    #define Zmin
    int DoPC(int cmd);
    int DoPCFloat(int cmd, float f);
    int DoPCInt(int cmd, int i);
    int MsgBox(char *s, int Flags);
    int SetVars(int poff, int varoff, int n);
    int GetVars(int varoff, int n, int poff);
    int GetToolLength(int index, double *Length);
    int SaveZLimits; //place to save limit switch settings
    double P0,P1,P2;
    main()
    int i,x,y,step,Xloop,Yloop;
    float Zpos,Xneg,Yneg,P0,P1,P2; //Xmax,Ymax,Zmax;
    float XMAX = *(float *)&persist.UserData[50]*StepsPerMM; //XMAX BY M100 Q FOR X AXIS,Checked and corrected User data OK 5/6/2018
    float YMAX = *(float *)&persist.UserData[51]*StepsPerMM; //YMAX BY M100 P FOR Y AXIS, Checked and corrected User data OK 5/6/2018
    float ZMAX = *(float *)&persist.UserData[52]*ZaxisIndex_mm; //ZMAX BY M100 R FOR Z AXIS, Checked OK 5/4/2018
    Zpos = ch2->Dest;
    //Calculate number of Loop for X and Y
    //Xloop = (XMAX / XaxisIndex_mm); //convert to the number of Xloops for 0.5mm steps in X, Checked and corrected formula OK 5/6/2018
    //Yloop = (YMAX / YaxisIndex_mm); //convert to the number of Yloops fro 0.5mm steps in Y, Checked and corrected formula OK 5/6/2018
    Xloop = (XMAX / (StepsPerMM*5)); //convert to the number of Xloops for 1.00mm steps in X, Checked OK 5/28/2018
    Yloop = (YMAX / (StepsPerMM*5));//convert to the number of Yloops fro 1.00mm steps in Y, Checked OK 5/28/2018
    SetBitDirection(1055,1); // Tool Probe input - SetBitDirection( ToolProbePin ,0) SetBitDirection(1055,1);
    // Move probe to starting position and zero DRO for Axis 0,1
    MoveAtVel(Xaxis,ToolProbeX,25000); // X Axis Probe start position
    MoveAtVel(Yaxis,ToolProbeY,25000); // Y Axis Probe start position
    while (ch0->Dest != ToolProbeX) ; // CHECK CONDITION!!!!
    while (ch1->Dest != ToolProbeY) ; // CHECK CONDITION!!!!
    Delay_sec(0.5);
    Zero(0); // Zero X axis position
    Zero(1); // Zero Y axis position
    Xneg = ch0->Dest;
    Yneg = ch1->Dest;
    Zpos = ch2->Dest;
    // Print the start position
    fprintf(f,"\n");
    //Start of Nested for loop
    int x=0;
    for(x=0; x<Xloop+1; x++) // 1st for Loop, loop however many Xloops make the increment and start probe at new X position
    int y=0;
    MoveAtVel(2,-ZMAX,8000); // y<Yloop=True. Move the z axis to the lower position at a low speed
    while(!CheckDone(2) && !ReadBit(1055)); // check for either probe contact or the end of the move !ReadBit(1055)
    P1 = ch1->Dest;
    { // 5/13/2018 now prints to file (!ReadBit(1055) removed !(Not) from Readbit
    P2=ch2->Dest;
    Delay_sec(.1); // Delay .1 seconds
    //MoveAtVel(1,(y+1) * YaxisIndex_mm,2000); // move to the next position 5/5/2018 added + (y + 1) * now moves to next Y position Yneg +, removed Yneg from formula 5/6/2018
    MoveAtVel(1,(y+1) * (StepsPerMM*5),2000); // Added to make next position 5mm 5/28/18
    while (!CheckDone(1)) ; // Original line "while (!CheckDone(0) && !CheckDone(1))"
    //fprintf(f,"\n"); // put an additional new line at the end to help discriminate this set of points, commented out 5/28/18
    } // End of 2nd Loop, Return to begining of Y for Loop for y<Yloop
    Move (1,Yneg); // Y Axis Probe start position, Checked and corrected OK 5/6/2018
    Delay_sec (.2);
    MoveAtVel(0,Xneg+ (x + 1) * (StepsPerMM*5),20000); // corrected axis call was 1 (Y axis) OK 5/6/2018, changed XaxisIndex_mm to StepsPerMM for 1mm step 5/28/18
    while (!CheckDone(0)&& !CheckDone(1));
    Delay_sec (.5);
    } // End of 1st Loop,Return to begining of X for Loop
    fclose(f); // X Loop Completed close file
    //completed Probing Return to Home Position
    I have also included the TXT file created by this program.
    I put a few comments in the program for " wish list" features to work on.
    If any one has some suggestions please share.
    Thanks Tom and the CNC zone community
    May 2006
    4045
    Hi eng101,
    Looks like you have a good start.
    FYI as a minor note if you post code using the cnczone code tag (# on the menu) it keeps the indentation so it is easier to read by everyone. Sometimes it is also necessary to replace tabs with 4 spaces.
    To get the current Origin offset you can see the ToolTableSet.c example for how to do this,
    btw this looks odd maybe you have your PQR parameters in the wrong order?
    If you need more than 3 parameters passed from GCode you might use another MCode to first set some persist parameters. Otherwise you might use GCode Variables.
    Regards
    TK
    Oct 2008
    39
    Hi Tom,
    You're right, I notice that while testing. when I ran a square section I didn't see it.
    It wasn't until ran a large rectangular part that something wasn't right.
    I had corrected myself in the Gcode for the M100 but didn't correct all the notes in the C program.
    My mom always said that I needed to mind my P's and Q's.
    Mar 2006
    37
    I was able to get this working on my machine. Thanks everyone who helped put this together. I was thinking I would need to setup Mach3 to probe. Much relief!.
    -Steven
  1. 3D probing to create point cloud.
    By eng101 in forum Dynomotion/Kflop/Kanalog
    Last Post: 04-05-2018, 02:49 PM
  2. Replies: 6
    Last Post: 02-09-2017, 06:48 AM
  3. Point Cloud
    By kstrauss in forum Tormach PathPilot™
    Last Post: 05-29-2015, 03:55 AM
  4. STL TO POINT CLOUD HELP PLEASE
    By GARTH LEE in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-22-2008, 03:04 AM
  5. Point Cloud
    By Freddy in forum Digitizing and Laser Digitizing
    Last Post: 09-24-2004, 04:18 AM
