586,119 active members*
3,517 visitors online*
    Mar 2018
    16
    Problems while playing a lasershow
    I can't play laser shows. During playing a show not all figures are visible. The laser is switched on in the first couple of seconds of the show but doesn't display anything. If I click a figure manually it is shown. Why is it not possible to handle this automatically?
    I use bILDA with a RGY-Laser. I already changed the colour settings (blue and dimmed beams should also be displayed)
    If I watch the show as simulation without bILDA the same problem appears. Could you provide some help?
    Please help.
    I didn't find the right solution from the Internet.
    References:-
    https://www.showeditor.com/en/forum/...lasershow.html
    Motion graphics video agency
    Re: Problems while playing a lasershow
    Hi there,
    You could try rewiring the connections as follow in this resource link. (http://pangolin.com/LD2000/qm2000pinouts.htm)
    Note that pinout is the same with every controller.
    This connection conforms to the ILDA DB-25 connector standard.
    Do give this a try and let me know how it works out.
    Thanks.
