586,094 active members*
3,859 visitors online*
IndustryArena Forum > CAD Software > Autodesk > Fusion 360 radius dish
Results 1 to 9 of 9
    Feb 2017
    12
    I’m new to fusion 360 and relatively new to cad in general. I’m attempting to model a radius dish and am sure it’s something simple but it has me stumped. Basically it’s a 24” circle that’s 0.75” deep and has a dished surface with a radius of 25’. Any help is greatly appreciated.
    35538
    Re: Fusion 360 radius dish
    Sketch half the profile and revolve it. I don't have Fusion here, so I'm not sure of the exact name of the revolve command.
    May 2006
    803
    I just bought one of those from Luthiers Mercantile except 15' radius.
    Cheaper than i can make it.
    What guitar are you making?i
    Feb 2017
    12
    I haven't got the style down that i want to build yet but I'm most likely going with a grand auditorium style body and then doing a cantilevered neck.
    I realize i could buy one cheaper than making one but I also know i could use the practice with F360
    Feb 2017
    12
    There are many ways to skin a cat. What I ended up doing was making a rectangle that was 0.75” tall and 24” long. I then made a vertical line and used the tangent and centerline functions to place it vertically through the center of the rectangle. After that I made a 3 point arc with a circumference of 300” and used the coincident tool to place the arc on the top corners of the rectangle. From there I used the push pull function with the equal to both sides to extrude the rectangle to a thickness of 0.0625”. I then extruded the arc across the 0.0625” depth and then the same with the vertical line through the body. I then split bodies with the arc and vertical line and removed the bodies I didn’t need. This left me with a 12” long body that had the arc in the top of it. Using the revolve function I chose the large face of the body that I had and chose the axis to revolve it around which was the face of the smallest height. After revolving full it makes a 24” circle with a 25’ radius dish
    Sep 2009
    1856
    If you have a look through the fusion forum there are quite a few guitar guys there
    http://danielscnc.webs.com/
    being disabled is not a hindrance it gives you attitude
    [SIGPIC][/SIGPIC]
    May 2006
    803
    Creekrat, this would be easily done in solids, 24' sphere and rectangular solid,
    boolean subtraction about 5 minutes to do the drawing , then direct to the CNC. does 360 do solids?
    What grand auditorium plans are you starting with ?
    I am doing dreadnaught molds and side benders from Georgia Luthiers Supply plans,
    they are great drawings full sized and verified a few times.
    Been doing this too long
    Feb 2017
    12
    Quote Originally Posted by bostosh View Post
    I'm not sure about the solids in Fusion but there is bound to be a similar function. All told, the way i did it took me about 5 minutes or so as well.
    [QUOTE=What grand auditorium plans are you starting with ?[/QUOTE]
    I haven't got any plans yet and want to work on a couple tele builds first and then most likely a cnc router build.
    May 2006
    803
    Go to Grabcad for starter files.
  1. Differing start and end radius Fusion 360 to Path Pilot
    By davidperry3 in forum Tormach Personal CNC Mill
    Last Post: 08-30-2017, 02:06 PM
  2. Replies: 11
    Last Post: 01-18-2017, 06:31 AM
  3. Need help forming a dish
    By siowenson in forum Bending, Forging, Extrusion...
    Last Post: 08-24-2007, 09:26 AM
  4. help forming a dish!
    By siowenson in forum MetalWork Discussion
    Last Post: 08-14-2007, 11:45 AM
