586,070 active members*
3,514 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > please help with tool path creating im still learning
    Nov 2011
    51
    I am new to fusion 360 and trying to learn the CAM feature and need a little help. Can someone help me toolpath a turkey box call body that I have designed in F360? I have a basic 3 axis cnc machine and just recently added a 4th axis indexer that i built. here is what I would like someone to help me with.
    1. add proper tabs on each end that i assume are required for 4th axis indexing.
    2. create a roughing toolpath with a 1/4 end mill
    3. create a finishing toolpath with a 1/4 ball nose bit.
    I already have the setup done and stock created in CAM but thats it. I have attached the file in a RAR archive it wouldn't let me attach the fusion exported file
    Thanks for any help
    Ronnie
    Mississippi
    Oct 2010
    171
    Re: please help with tool path creating im still learning
    First question: do you have Fusion 360 Ultimate? I assume you must since the standard version does not do 4 or 5 axis CAM.
    Second question: can you increase the two corner radii that are .100"R to something just a touch over .125"R so you can get fully into the corner with your 1/4" end mill?
    thx
    Nov 2011
    51
    Quote Originally Posted by precisionmetal View Post
    Yes, that would be fine
    thx
    Yes. I have ultimate. I have attached what i have come up with thus far. please feel free to post your file because i would love to see other toolpathing strategies
    Oct 2010
    171
    I would probably take an approach something like this:
    - add "width" to your blank, then pick it up like in my example and face/profile in that direction
    - flip the part 180° and pick up in contoured/soft jaws with the shape required, and face the remaining material off the other "side"
    - grab part "upright" in stepped jaws (now finished completely on the outside), and machine the pocket
    I have not addressed your full corner rounding you show in your model, but don't know what you have for tools.
    Link to file --> https://www.dropbox.com/s/pc6lw2m9mf...20PM1.f3d?dl=0
    PM
    Nov 2011
    51
    Thanks for taking the time to do this. I am about to check it out now.
    - flip the part 180� and pick up in contoured/soft jaws with the shape required, and face the remaining material off the other "side"
    PM
  1. Creating Tool Path for Cutting Wedge/chamer
    By 4Bio in forum BobCad-Cam
    Last Post: 07-09-2016, 01:41 PM
  2. Replies: 0
    Last Post: 02-12-2015, 11:04 PM
  3. Replies: 2
    Last Post: 12-15-2013, 05:09 PM
  4. Need help when creating surface tool path
    By gorby in forum Mastercam
    Last Post: 11-25-2009, 02:25 AM
  5. Learning path
    By Dreadluthier in forum Benchtop Machines
    Last Post: 11-11-2007, 06:05 AM
